20 Most Recent
RCA H5450RE3 Accessory Handset For -25450 Phone Questions & Answers
My speakerphone doesnt work on my 25423re1-a ,but my handset does work ? how can i fit it , thanks Ben Brazzell
Ensure that the speakerphone feature is not disabled. Some phones have a dedicated button or an option in the phone menu to enable or disable the speakerphone. Look for this option and make sure it is turned on.
Or Reset the phone to factory settings. Refer to the user manual of your 25423RE1-A phone for instructions on how to perform a factory reset. Keep in mind that this will reset all settings and may delete any personalized configurations.
How do I turn off a second alarm on the RCA Digital PLL radio model RP3711A?
To turn off the second alarm on the RCA Digital PLL radio model RP3711A, follow these steps:
1. Press and hold the "Alarm 2" button on the top of the radio until the display shows "OFF."
2. Release the button.
3. Press the "Alarm Set" button to confirm that Alarm 2 has been turned off. The display should no longer show the time and alarm settings for Alarm 2.
If turning off Alarm 2 using the above steps doesn't work, you can try resetting the radio to its factory settings. To do this, follow these steps:
1. Unplug the radio from the power source.
2. Remove the backup battery from the radio.
3. Wait at least 30 minutes.
4. Reinsert the backup battery and plug the radio back in.
5. Set the time and alarm settings again.
Regarding the manual, the model RP3710 and RP3712 may have similar features and operation, but it's best to refer to the manual specifically designed for your radio model RP3711A to ensure that you are following the correct instructions. You can usually find the manual online by searching for the model number on the RCA website or on other electronic manual databases.
