20 Most Recent RCA 20F610TD TruFlat TV/DVD Questions & Answers
The sound has gone on my TEAC LCDV1901M tv
have u tried the volume control on the side panel of the tv...if that does'nt work , unplug the tv and leave it off for a five minutes ...also you can try going into the menu mode of the tv and factory reset it...hope this help...
5/3/2014 2:59:17 AM • RCA 20F610TD... • Answered on May 03, 2014
My portable rca dvd player makes loud sound when
the cd is touching the base while it is spinning...i came across a similar problem and used a flathead screwdriver and gently pry the cd plate upwards so there is a little space ...otherwise take it to a repar shop...
5/2/2014 4:40:09 PM • RCA 20F610TD... • Answered on May 02, 2014
Put vhs in tv, now it won't switch back to tv
see the following step:1) clean with VHS tape clean the inside componets, rollers, sensor,idler wheel2) inspect any belt worn or broken.3)clean with cotton pads, any parts with small amount of alcohol isoprophilic.4) clean any sensors electric inside very well, and tight connector.normally when some sensor NOT switch back to turn TV. God bless you
7/21/2012 1:38:25 PM • RCA 20F610TD... • Answered on Jul 21, 2012
I have rca tru flat tv w/built in dvd and i have universal remote I cant get the dvd set on the remote also I cant get dvd to rewind or fast forward
HelloIt will be very difficult to get all functions of the RCA device, synchronise with a universal remote control. Just find a code, whic has maximum finctionality. That is all we can do. Just try an other code for RCA TV to universal remote. I hereby send some codes to check. OKTV: 1144 DVD: 3423, TV: 1146 DVD: 3424 TV:045 DVD:091
1/21/2012 10:49:40 AM • RCA 20F610TD... • Answered on Jan 21, 2012
My dvd player hard drive sometimes makes a loud humming noise when the dvd stats to play?Is it an unbalance or the drive going bad? Is the drive easy to replace? Thanks.
it can be caused by a bad sled motor. Possible. no, not for the novice. unless you have experience replacing this, can damage beyond repair.
12/8/2011 7:44:07 PM • RCA 20F610TD... • Answered on Dec 08, 2011
2answers
Popping sound and nothing works
You could have a power issue, or any number of issues with some of your chip boards. As the inside of TV's store a lethal amount of electricity I would strongly advise you get the tv checked by an RCA repairman. It may end up costing you more money to fix the issue than repair it. Ask the tech to give you an estimate before any repairs take place.
11/6/2011 1:04:19 PM • RCA 20F610TD... • Answered on Nov 06, 2011
RCA Tru Flat 20" TV/DVD Combo Remote and manual
Hi
Check its speaker first. If it is Ok, check whether the volume is set to zero, or mute function is ON. If all of the above is OK, the audio output IC of your tV is faulty. You ahve to replace it with same type and number. Audio IC can be located by following the speaker wire. One end of that wire will go to oudio output section. There will be an IC; usually screwed on to a metal heatsink. Check its solder terminals first, for any loose soldernng. It is best to resolder all the solder terminals of that IC, by applying a little more solder, without making any solder bridge in between adjecent solder points. If this resoldering also does not help you, check the voltage at the pins of that IC. The maximum voltage will be between 25 and 24VDC. If the voltage also is there, and still there is no sound, replace the IC with same type and number, provided the speaker is good. OK.
7/12/2011 6:13:44 PM • RCA 20F610TD... • Answered on Jul 12, 2011
Somehow the parental lock was
Hello
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Any one amoung the above process will unlock your GE TV. After unlock, you have to do the Vchip-Set. OK
5/10/2011 5:06:04 AM • RCA 20F610TD... • Answered on May 10, 2011
2answers
Lock code how to un lock it
If you have a RCA Truflat TV/DVD combo try code 8888 to unlock parental control settings.
3/25/2011 9:40:51 PM • RCA 20F610TD... • Answered on Mar 25, 2011
I have a 20'' RCA TruFlat SDTV/DVD combo that's
The RCA tv's have the highest breakdown problems in the industry and usually take a slew of parts in the process when they finally quit. Now if you are very lucky you may have bad connections on the main board, but with history these sets carry I'am inclined to run it until it fails completely and buy a new tv.
1/2/2011 2:47:48 PM • RCA 20F610TD... • Answered on Jan 02, 2011
I have had my t.v
houseofesthe
With modern electronics with they are turning off and on by theirselves this is a sign that you have a short to the TV some where. The reason for this is there is a contact switch and if the mainboard builds up a charge it will bridge the switch and activate it.
The common thing to check is the connection for the fuse. Alot of times you do not have a good connection and there is a arc which is causing the charge to build up.
Another thing to check is your other devices that are connected to the TV. They may have a ground fault that is grounding to the TV. I would disconnect all your other devices to see if the problem goes away. If it does the problem is not with the TV.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
11/5/2010 10:58:27 AM • RCA 20F610TD... • Answered on Nov 05, 2010
Looking for comcast remote code for a rca truflat
<a heref="http://universalremotecodes.blogspot.com/">Magnavox Universal Remote</a> check the codes here
7/18/2010 7:27:19 PM • RCA 20F610TD... • Answered on Jul 18, 2010
Good morning, My tv is only 3 1/2 years old. It
Hi, there must be something wrong in the power supply circuit, usually because of bad or off value components, if the TV actually gets a picture and cutts off, the power supply could be the circuit to suspect, if the tv does not give a picture, it only does the click and the power light turns on but nothing else happens, there could be something else wrong besides the power supply circuit.
3/20/2010 6:10:19 PM • RCA 20F610TD... • Answered on Mar 20, 2010
0answers
Hi i already programed dvd/tv to the universal
Manufacturer RCA Part Number 262339 Description REMOTE CONTROLuniversal remote no can doing programed ......
9/28/2009 7:22:30 AM • RCA 20F610TD... • Answered on Sep 28, 2009
Horizontal lines/"snow"
it sounds as iff it the arial connections ?? are the problem check the connections you may need new cable? use 75 ohms cable
4/23/2009 7:21:51 PM • RCA 20F610TD... • Answered on Apr 23, 2009
RCA 20F610TD TruFlat TV/DVD Logo
33 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
dvd not working
  • Televison & Video
