20 Most Recent
RCA RP5015 Digital Voice Recorder Questions & Answers
I have an RCA Digital Voice Recorder Model No: RP
This model saves audio files to internal memory therefore it seems everytime it drains battteries out it loses the data. Consider a new model with Memory Card or buy normal batteries that drain out after 12-15 months or Duracell precharged rechargeable ion batteries they say last 5 years.
DONT HAVE THE OWNERS MANUAL
I lost my manual for instructions can you send another or is there a pdf file with instructions please help
Deleting Files
1. Select folder (A/B/C/D)
2. Select file.
3. Press ERASE once and DELETE will
blink on the screen.
4. Press and hold ERASE for 3 seconds
to confirm deleting. (or press STOP to
cancel erasing file)
RCA 5011A
press play then press the forward button >>|
it will say FIL:01 and if you keep pressing the >>| button it will go to the next file if there is one. when you see the file you want to delete pres ERASE, it will blink and say dEL:01 or 02 or whatever file you want to delete, press delete again and it will be gone. hope this helps, i lost my manual and am trying to go from memory and this thing is not easy to figure out and i am very mechanically and technologically inclined for a girl.
RP 5011A
I only need a operating manual. Unable to use the recorder since I don't have instructions. I can set the time. I just don't know how to set the recording or erase it.
My RCA home theater system,
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
1/15/2024 9:01:27 AM •
RCA Audio...
Answered
on Jan 15, 2024
