20 Most Recent
Ricoh Aficio AP4510 Laser Printer Questions & Answers
Can i have solve my proplem is sc 542
sc542 is a fuser code that needs to be reset by a service technician. It may be just a dirty sensor or it could be something more serious. Contact your local Ricoh service tech for assistance.
How do i seperate the drum unit from the dev unit
For the 4510, the two units are provided together as one supply item and are not meant to be separated. However, if you do need to separate them, there should be two vertical screws (one in the front and one in the back) and a couple of screws on the metal plate on the backside of the two units.
Be careful when separating the two units. There is toner that can easily spill out of the PCU if it is flipped over.
When I'm trying to print
Hi, this seems quite a simple issue with the printer. Duplexer has a doorswitch that occasionally goes bad (or more likely unplugged).
Check for the switch and that should resolve the issue.
I have Ricoh Aficio MP c2800, Machine say toner undetectable all four when i check system status and yellow, cyan is not show up on copies at all
If your Ricoh Aficio MP C2800 is showing "toner undetectable" messages for all four toner cartridges and the yellow and cyan colors are not showing up in copies, there may be several potential causes for this issue. Here are some troubleshooting steps to help you resolve the problem:
- Check Toner Cartridges: Ensure that all four toner cartridges are correctly installed and securely seated in their respective slots. Make sure there are no protective seals or tapes left on the cartridges.
- Shake Toner Cartridges: Sometimes, toner inside the cartridges can settle or clump, leading to detection issues. Gently shake each toner cartridge side to side to redistribute the toner evenly.
- Replace Toner Cartridges: If the toner cartridges are old, empty, or expired, replace them with new, genuine Ricoh toner cartridges.
- Clean Contacts: Dust or debris on the toner cartridge contacts can interfere with communication. Use a soft, lint-free cloth to clean the electrical contacts on both the toner cartridges and inside the printer.
- Check Developer Unit: The developer unit in the printer plays a crucial role in toner development and transfer. Ensure that the developer unit is clean and free from any obstructions.
- Perform a Firmware Update: Check if there are any firmware updates available for your Ricoh MP C2800 printer. Updating the firmware might address known issues and improve printer performance.
- Reset the Printer: Power off the printer, unplug it from the power source, wait for a few minutes, and then plug it back in. Power the printer on to see if the issue resolves.
- Check Toner Detection Sensors: The printer uses sensors to detect the presence of toner cartridges. Verify that these sensors are functioning correctly and not blocked by any debris.
- Perform a Factory Reset: As a last resort, you can try performing a factory reset on the printer. However, be aware that this will reset all settings to their defaults, and any custom configurations will be lost
