20 Most Recent
Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo Drive Questions & Answers
Player does not out put sound
You are not able to get the sound with the video that you are burning as the burning software has expired and you need to purchase it. However there are other free software that does the same as Nero. You can try
BurnOn CD & DVD burning software for the same and enjoy all the videos as it is absolutely free.
Cheers!
9/30/2019 2:07:33 AM •
Samsung...
Answered
on Sep 30, 2019
Cd drive not working
One thing you can do is in device manager, delete the device, reboot the computer and see if it finds the device and reinstalls the software for it. If it does not, there is a high probability that the drive is bad or the IDE controller in the computer has failed. Windows XP is no longer supported.
3/24/2017 11:28:50 PM •
Samsung...
Answered
on Mar 24, 2017
Not reading the dvd
clean dvd check for scratches sometimes you can fix them with scratch kit
5/8/2016 6:45:59 PM •
Samsung...
Answered
on May 08, 2016
How to change setting for dvd drive
Update the drive firmware. See
http://www.samsungodd.com/eng/firmware/FWdownload/FWDownload.asp?product_code=language_code=SearchMode=TOTALSEARCHSearchWord=SH-S223Cimage1.x=0image1.y=0.
Be sure to select the correct version for your drive.
1/28/2015 11:23:09 PM •
Samsung...
Answered
on Jan 28, 2015
TSSTcorp CD/DVDW SH-S182D
It is too late to find out the issue and return SH-S182D drive.
SH-S182D drive has compatibility issue, none of firmware (including the latest) is "perfect" so far.
I couldn't do anything but wait for Samsung to release new firmware to fix their drive.
Same **** with my Samsung SH-S182M. In a nutshell, it burns DVD's then
can't read them while my old, cheap DVD reader can. Once in a while it
manages to read one making me think I've fixed the problem.
All i can say to you is buy a new one my friend.
If i am helpful to you, please rate me.
Thank you.
Yboyandrei
12/18/2014 2:14:47 PM •
Samsung...
Answered
on Dec 18, 2014
I have a Samsung combo
It is most likely your drivers are not correct or not up to date.
I'd do a search for your model to get the correct updated driver installed for your operating system.
could also be the software you are using to burn.
Most computers come with something like neroburn which should work for a basic install but may have some issues with certain types of CDs. I'd try to just write one small file onto both a re-writable and a write only desk and see if it make a difference. You could always downlaod a freeware cd burner and see if it is a software issue.
sincerely dought it is your cable connections but you can make sure the IDE is connected all the way on each end, but if it's running it shouldn't be the cables.
7/2/2011 9:26:48 AM •
Samsung...
Answered
on Jul 02, 2011
Sofware cd-rw/dvd drive SH-M522C/BSBN
Click on Start, Run, and typeregedit and press Enter
Click on the plus signs (+) infrontof the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Then click on
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown , right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
Sarjun (Dip. Civil Eng, iNCED)
7/1/2011 4:30:10 AM •
Samsung...
Answered
on Jul 01, 2011
My Samsung combo drive (TSST
you might have to
physically unplug the leads for this cd/dvd rw then plug them back in or
you might have to uninstall
then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel
administrive tools computer management device manager scroll down cd dvd rom
drives if you see a yellow question mark? right click you will have
options to update driver,roll back driver,or
select properties general
troubleshoot, select driver click to reinstall drivers click update
driver or uninstall then reinstall
Click start control panel
administrive tools,computer management,device manager scroll down cd-dvd rom
drives you might see a yellow question mark ? right click you will have
options to update driver,roll back driver,or select properties general
driver or uninstall then reinstall if this does not fix the problem it might be
a registry problem if you cant see your disk drive in windows explorer
Close all open
programs
Click on
Start, Run, and type regedit and press
Enter
next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
Hope this helps
6/29/2011 4:38:14 AM •
Samsung...
Answered
on Jun 29, 2011
Please help me, i have
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps
6/3/2011 6:56:08 AM •
Samsung...
Answered
on Jun 03, 2011
My Samsung combo drive does
It is likely that the laser diode for CD reading and writing has burned out. DVDs use a different laser diode. If this functionality is important to you, replacement is the only option.
3/13/2011 5:39:45 PM •
Samsung...
Answered
on Mar 13, 2011
Code 10 CD/DVD drive
Do you have itunes Installed and Vista? If you please uninstall itunes.
3/1/2011 2:18:33 PM •
Samsung...
Answered
on Mar 01, 2011
MY COMBO DRIVE IS NOT
Does it read them and just not play them this could be codecs are needed if you have Windows Media player you will need certain codecs in order to play some movies. I use a product called
VLC Media Player and use it as my default player as well as
XPBurner for all my burning needs. XPBurner works with Win7 if that is what you have.
It is most likely codecs if this is not the case you might consider a fresh boot unplug the computer from the wall then push the power button in for 3-5 seconds then plug the computer back in and restart the system it should fix this issue. If this does not work and you have installed codecs proper then you may consider a new combo drive. This may be the ultimate issue I hope this assisted you. Click the links I have sent to you to possibly fix this issue. Thanks for using FixYa! John
2/12/2011 6:42:08 PM •
Samsung...
Answered
on Feb 12, 2011
Unit will not read or
first things, go to start and then, settings , then control panel... open your system icon, device manager, i assume u were already here as you said the device said it worked properly. try uninstalling the driver. if u have a reg cleaner, run it at this time. then re-boot your computer and let it re-install your driver. this seems to work on alot of systems that people have problems with the peripherals. of course, im sure u have already looked to make sure u are running the latest driver ...:)
cheers....PK
1/16/2011 7:14:58 AM •
Samsung...
Answered
on Jan 16, 2011
My Samsung R530 Laptop, has stopped writing dvds,
HI Frank,
Download and install CCleaner
(free) from Piriform
Run the cleaner to remove old
un-needed temp files
Select the StartUp tab and look
for any programs that you know you installed but no longer use or
need, and disable them. Caution, do
not disable any system files unless you absolutely know what they
do and that you do not need them.
Run the Registry cleaner, when
asked if you want to backup the registry, select YES,
and save to a file you will remember just in case. I have used this
program hundreds of time on many different system and it has never
caused a problem, but you want to be safe, backup the Registry.
If asked about a particular file
that it wants to clean, select "yes to all"
Reboot
Windows should reinstall the drive when
the computer boots back up.
If this does not resolve your problem,
try the following.
If you take all these step and you
still can not burn a DVD or play CDs, chances are your CD/DVD burner component needs
to be replaced. Good Luck.
1/1/2011 2:59:50 AM •
Samsung...
Answered
on Jan 01, 2011
Writing problem
Make sure your processor at least dual core.
Your power suplay unit is "true power" or rue rating. (fluxtuative voltage can causes writing problem).
Make sure your RAM at least 1 GB.(2 is better).
Turn of your Antivirus program when you burn a CD.
12/2/2010 8:37:32 PM •
Samsung...
Answered
on Dec 02, 2010
