20 Most Recent
Samsung SyncMaster 793DF 17" CRT Monitor Questions & Answers
What is "flyback" on tv monitor
the "flyback" is the VERY high voltage transformer that powers the CRT through a cable that plugs into the CRT inside the monitor case. Don't try unplugging, even with power off, as it has to be discharged to ground to remove risidual voltage, like a capasitor. This voltage is about 35,000 vdc.
12/1/2014 3:26:35 PM •
Samsung...
Answered
on Dec 01, 2014
What is "flyback" in a tv monitor
A
flyback transformer (FBT), also called a
line output transformer (LOPT), is a special type of electrical
transformer. It was initially designed to generate high voltage sawtooth signals at a relatively high frequency. In modern applications it is used extensively in
switched-mode power supplies for both low (3V) and high voltage (over 10 kV) supplies.
this is use only on monitor the old one that used CRT TUBE.
12/10/2013 1:58:40 AM •
Samsung...
Answered
on Dec 10, 2013
My samsung monitor is emitting excessive heat
what particular part in the crt monitor?. if the horizontal transistor in the board which mean somewhere in the board getting bad. if just only a heat which emit by the whole unit it was normal since it was a CRT type unit. just let me know what part did you asking so i can give you further solution good luck.
9/16/2012 6:45:46 AM •
Samsung...
Answered
on Sep 16, 2012
My respected sir ,when i start my pc icould not
Time and aging of the machine and it hardware components.When it is winter or rainning seasons tries to keep the computer on and running every two a day even u are not using it,too it is not to putting to much more pressure and stress on the the computer components to have start up cold and put on much more stress of the season of that year stress for hardware of the computer to do the powering of the computer to restart booting sequences again.
10/6/2011 5:55:34 PM •
Samsung...
Answered
on Oct 06, 2011
On and off switch problem
Would suggest you get a new one,since monitor are not that expensive, note that the monitor has a large capacitor which stores charge in high voltage,it will not be good for somebody without the required skills to open this monitor.It can lead to serious injury,better still if you cannot buy a new one,please give it to a technician to do it for you.
Regards
11/25/2010 3:37:31 PM •
Samsung...
Answered
on Nov 25, 2010
The display has turned yellow.
Possibilities:
* bad connection of video-cable to monitor
* bad connection of video-cable to computer
* bad video-cable
* bad monitor -- connect to a different computer to see if it works, or displays the same symptom
* bad video-card -- connect a different monitor to see if the symptoms persist
It's probably time to responsibly-recycle that CRT, and spend $100 to buy a new 19-inch LCD monitor.
10/23/2010 9:10:09 PM •
Samsung...
Answered
on Oct 23, 2010
How can i disassemble this
For a copy of the user manual you can go to:
http://online.manualspace.com/computer-monitors-free-ebooks/samsung-monitor-service-manual/4207/samsung-syncmaster-793mb-793df-crt-monitor-service-manual-91.html
Scroll down this page and you will see a red link entitled "Download Samsung SyncMaster 793MB 793DF CRT Monitor Service Manual".
Right click on this link and select the menu option "Save Link As".
Save the file to your computer then you can simply use Winrar to extract the file.
Would you kindly rate my answer please if this has helped resolve the problem - thanks :)
10/20/2010 8:42:54 PM •
Samsung...
Answered
on Oct 20, 2010
My screen is turning black sometimes halfway
The picture board on your monitor is bad, since it turns
black atimes, it means the
board of your monitor has developed fault.
The best thing for you
to
do now is to take the monitor to a local repairer within your vicinity or any service center
to help with the replacement of the picture board
because the fault is not something you can fix yourself. in order not to
complicate issues.
Take care.
4/22/2010 11:48:41 AM •
Samsung...
Answered
on Apr 22, 2010
Horizontol size is 100 but still size is small
there is a diode near E.H.T.which is double and connected in series internally replace it. if persist then there is transistor near E.H.T. check it .it may faulty replace it
3/5/2010 12:49:18 PM •
Samsung...
Answered
on Mar 05, 2010
Dear sir,
try to wiggle the vga cable/dvi cable and see if the brown lines disapear, if not.there is a problem with the monitor
11/3/2009 2:37:09 PM •
Samsung...
Answered
on Nov 03, 2009
