20 Most Recent
Samsung TX-R3080WH 30" TV Questions & Answers
TV turns off after a few seconds
it could be the bulb on the way out, they don't like to turn on if the inverter does not get a voltage use from the bulb, while trying to turn on the tv look at the vents for the bulb if you see it flicker on and of while trying to turn on the tv when it would be the bulb. when the tv is on and work hold a peace of paper over the vent not to cover it but to look at the bulb light if you see a flicker or bright and dim and repeats doing this then the bulb is warn out. if you hear clicking or scratching sounds this could be the inverter board on it way out.
7/3/2017 3:03:59 PM •
Samsung...
Answered
on Jul 03, 2017
When i turn the T.V on it turns right back off
The capacitors on the power board have most likely blown
Simply re solder new caps in place of the ones that have buldged on top
If you have soldering iron and skills you can do it yourself
The parts will only cost you about £2
a TV shop will charge you £80
4/5/2011 3:14:54 PM •
Samsung...
Answered
on Apr 05, 2011
Buzzing sound after warm-up won't
This problems are comming from the power supply board it iself.That the board,where the power a/c cord plug into it.Tries putting in supper glues all over the those big tranformers on the power supply board to cover up those gaps for exscapping high pitch current humming.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
1/27/2011 3:32:25 PM •
Samsung...
Answered
on Jan 27, 2011
Samsung TX-R3080WH, tv is less than 2 years old
not sure about this model but it sounds like the backlight has gone out. You can call samsung at 1-800-samsung and they may be able to help or give you the # of the nearest service center.
12/8/2009 10:53:22 PM •
Samsung...
Answered
on Dec 08, 2009
SAMSUNG TXS3082WHX/XAA Won't Turn On
All of these tv's are board replacement only the individual parts are not available. The boards can cost anywhere form $200 - $400 each. Even if you do it yourself it is still an expense, if you get the blink code i can point you to the correct board. These sets have different boards even within the same model range. One of the first diagnostics is does the back light come on, if not then you either have a balancer error or a bad bulb in the panel. Why i suggest this is because it is the most common problem. If it is the bulb in the panel you have to replace the whole panel, the bulbs are not available as an individual part.
9/2/2009 2:22:46 AM •
Samsung...
Answered
on Sep 02, 2009
Turn it on, no picture for a while. Then picture
G'Day!
Unfortunately, what you're describing is a repair
issue. You won't be able to address the problem with troubleshooting.
There is a part inside the TV that needs to be replaced. If you're
under warranty, this will cost you nothing. If you're not under
warranty the cost will likely be a minimum of $200 parts and labor.
However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
7/29/2009 4:35:54 AM •
Samsung...
Answered
on Jul 29, 2009
My tv txs3082 blink constantli
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
7/22/2009 10:01:22 PM •
Samsung...
Answered
on Jul 22, 2009
I bought my Samsung TX R3080WH, 30 inch tv in Sept
Sounds like the capacitors in your power supply had burnt out causing to high of a voltage which can cause a threat to other system boards and components. You will need to have your power supply tested firstly.
3/10/2009 1:29:04 PM •
Samsung...
Answered
on Mar 10, 2009
Turns off and on with no help from me
are you a technician if so go to the relay circuit and fix that circuit more than likely has bad ic like the eprom .
are leaky transistor also check the power button for lose connection they are tiny little switches now a day
2/22/2009 4:07:03 AM •
Samsung...
Answered
on Feb 22, 2009
No picture
Bad solder connects....needs chassis pull,careful soldering..
not the picture tube.....................T.
11/26/2008 4:10:07 PM •
Samsung...
Answered
on Nov 26, 2008
Dropped TV
Hi craigaloid
your problem is the flourecent lamp on that side it could be broken after it fall have a tech look at your tv for repairs.good luck
5/3/2008 3:46:41 PM •
Samsung...
Answered
on May 03, 2008
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
2/27/2008 12:50:49 AM •
Samsung...
Answered
on Feb 27, 2008
