20 Most Recent
Samsung HL-R5087W 50" HDTV-Ready Television Questions & Answers
Hi, I've been using my
take it to a repair shop for a proper diagnosis of the problem
the set uses very old technology and will be more expensive to run then the latest LED units
make the decision after you are acquainted with the repair costs and running costs of a new unit ( remembering that there is a warranty period with the new unit as well)
9/8/2017 12:32:11 AM •
Samsung...
Answered
on Sep 08, 2017
Has Great Sound But No Picture
Could be either the bulb has burnt out or the bulb ballast needs replacing. I have the 5687 set and it is dynamite.
Check out ebay for better prices on replacements.
3/24/2017 1:49:01 AM •
Samsung...
Answered
on Mar 24, 2017
Why does my samsung 50 inch hdtv keep turning off
Try to check the bulb if defective, if the lamp is defective try to replace it, after replacing the lamp be sure to reset the lamp hour meter. good day and best regards. Hope this may help.
8/31/2011 3:57:05 PM •
Samsung...
Answered
on Aug 31, 2011
Problem concerns Samsung HL-S5087W.
3 blinking led light at the front panel is an error code for lamp malfunction. If you've already replaced the bulb and yet the symptoms remain the same, then high chance that the fault came from the
ballast board because the supply voltage is present.
Confirm if the bulb will lit upon powering on the unit. Open the lamp cover, bypass the lamp cover switch by putting tape to make it in closed position (making it still the lamp cover is attached to the housing) and then power on the unit. Check if the bulb will ignite or will light up, if not, you have to replaced the
ballast board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
7/14/2011 11:12:30 PM •
Samsung...
Answered
on Jul 14, 2011
