20 Most Recent
Samsung HT-HDP40 System Questions & Answers
I am looking for the clips that goes onto the raw
Normally the speakers and receiver just have a hole that lines up when you push on the head, and a spring pushing back makes contact on the bare wire, when you let go. But if your receiver has jacks or screw terminals instead, then you will have to get them at Radio Shack. They just crimp onto the wire with a pliers or special crimping tool.
My 5 disc dvd player
The laser lens circuit itself is faulty if cleaning doesn't work. The capacitors and other components can wear out and overheat and burn out through time. You can get another from many suppliers including ebay. and
http://www.toocle.com
www.tradekey.com
or try to adjust the lens. See how:
www.ehow.com › ... › DVD Players & Recorders › DVD Players
Speaker wire connector
Yes you can try Bogue Engineering at
www.BogueEngineering.com they carry awesome connectors and for your system you need the 4,2mm size. They only cost $21 for a set of 6 and they are much better than Samsungs parts. Hope that helps.
Gary
DVDs freeze every few seconds while playing
this could be from a number of issues. first is it a home made disk? second the type of changer you are using?
home made disks can be fixed by using a + or - disk depending on the disk and what the drive likes.
as for the second issue it could be a cooling issue or the lens might be dirty try blowing it out with some can air and try to use a lens cleaner disk. they should be able to sell one for about $5 - $10
Samsung HT-HDP40 Equipment needed
http://www.samsung.com/download/agreement.htm is where you want to go to get everything you need for your unit! Click on agree and enter your model number, as this is not a US model and this model has to come from the global download center. Good Luck
Hi, I'm using the Samsung HT-E330K. It works but does not speak out. The power display is fine but no sound
If your Samsung HT-E330K home theater system is not producing any sound even though the power display seems to be working fine, there are several potential causes and troubleshooting steps you can try:
1. **Check Volume Levels:** Make sure the volume on the home theater system and the connected TV (if applicable) is turned up and not muted.
2. **Check Audio Source:** Verify that the correct audio source is selected on the home theater system. If you're using multiple input sources (DVD, TV, AUX, etc.), make sure the right input source is selected.
3. **Audio Cables:** Ensure that all audio cables are securely connected to both the home theater system and the audio source (TV, DVD player, etc.). Sometimes, loose or faulty cables can result in no sound.
4. **Speaker Connections:** Check that all speakers are properly connected to the home theater system and that the speaker wires are securely inserted into the appropriate terminals.
5. **Audio Settings:** Go through the audio settings on both the home theater system and the connected TV (if applicable). Ensure that the correct audio output settings are configured.
6. **Mute Function:** Double-check that the mute function on the remote control or the home theater system itself is not engaged.
7. **Speaker Balance:** Check the speaker balance settings to ensure that sound is not unintentionally directed to one side or speaker.
8. **Reset to Default Settings:** If you've made any changes to the settings recently, consider performing a factory reset to revert to the default settings.
9. **Firmware Update:** If there is a firmware update available for your home theater system, consider updating the firmware as it might resolve any software-related issues.
10. **Test with Different Source:** Test the home theater system with different audio sources to rule out issues with a particular device.
11. **Test Speakers:** If possible, disconnect each speaker one at a time and test the audio to identify if a particular speaker or speaker wire is causing the issue.
12. **Check Speaker Impedance:** Ensure that the speakers' impedance matches the specifications of the home theater system. Mismatched impedance can affect sound quality.
13. **Contact Support:** If you've tried these steps and still have no sound, consider contacting Samsung customer support or seeking assistance from a professional technician for further troubleshooting and repair.
Remember to refer to your device's user manual for specific instructions related to your model.
