20 Most Recent
Samsung SPP4231 42 in. EDTV-Ready Plasma Television Questions & Answers
I have a Samsung model
This kind of symptoms indicated of fault in the Y-sustain board inside the unit. This is responsible for the horizontal scanning. Hybrid module gone to excessive heat due to overload that trigger the symptoms after a period of time of operation. The problem is, this module is repairable only at the service center because this parts and other parts are surface mounted, even we, technician, has a hard time replacing this part.
Check if your unit is still under warranty/extended warranty, avail it because the manufacturer will fix it for free. This board is expensive, range from $200-$300. Don't attempt to open the back cover because it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
My Samsung SP-P4231 has sound
Go to eBay and search for BN96-01217A.That is the power board used in SP-P4231 and the most common reason for the problem you have.(not guaranteed, just statistically most likely one; if you care to check measure the Vs voltage at the power output - shoudld be about 87V and will probably be much less, say 30V)Hope this helps!bobby @ coppelltvrepair
http://www.coppelltvrepair.com
My Samsung SP-P4231 plasma television
The tv main Tuner signal board have intermittent problems,sorry this problems it could be anythings wrong in the board as parts wise are dying in the tv Tuner signal board just not completely,that why it take times to show up,that the board where the tv incomming broadcasting signal cable plug into it.U can take things aparts and putting it back together again?Yes.Try website like Ebay.com to buy a refurbish main Tuner signal board for the replacement.Or take to the shop for the repair that it.
I have a samsung sp-4231 plasma tv and after the
Sounds like something you will need to have the professionals diagnose, because that seems like a very uncommon error with that line of TV's. Sometimes TV's just go bad, and need maintenance, especially newer TVs.
Screen black out
this is a upper buffer board problem, the board is not to expensive but the if you are not a repairman, I would not attempt it
