20 Most Recent
Samsung LN-S4041D 40 in. LCD HDTV Questions & Answers
My Samsung HDTV takes almost
Tv have a power supply board problems.That the board where the tv power a/c cord plug into it.Take the tv aparts and check the tv power supply board carefully for dying and leaking components parts that are calling capacitors parts these capacitors parts are most likely bugles ups or puffing up onto it tops and leaking.These capacitors parts are dying and leaking that why it give the tv power supply board low power and long time to power up the tv.Have all the tools and know basic electronic also can do basic soldering work?Yes,than changes all these dying and leakages bulges ups capacitors components parts with the same Miro Fared and thoes voltages on the capaictors parts like 5 or 10 volts higher than those capacitors parts was in the power supply board u are replacing,these 5 or 10 volts higher rating will help these newly replace capacitors parts withstand heat better and last longer and the operation on the tv power supply board.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power suply board for the replacement.
10/30/2018 3:16:29 AM •
Samsung...
Answered
on Oct 30, 2018
Samsung television wont turn on
there is a defect in your tv.there is parts on it shorted consult your samsung service center to fix your problem
7/17/2018 4:41:46 AM •
Samsung...
Answered
on Jul 17, 2018
I have a Vizio VX42LHDTV10a To fix screen that
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
5/8/2017 11:35:29 AM •
Samsung...
Answered
on May 08, 2017
3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
9/3/2015 3:00:28 PM •
Samsung...
Answered
on Sep 03, 2015
Tv makes clicking noise but won't turn on
it is a power supply issue. options 1- replace the power supply
2- this unit has an issue with 4 capsitors on the power supply which sit side by side and are about 10 volt each replace them with standard 16v caps.
5/25/2015 3:00:04 AM •
Samsung...
Answered
on May 25, 2015
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are
the problem. However, I think that if you have some minimal skills with
soldering, you can fix this yourself. You just need to take out the
system board, then the power supply parts are on the top right. The bad
capacitor(s) will be bulging at the top and possibly have some brown
stuff coming out. The ones that go bad are 1000microfarad, 10V, however
you can replace them with higher voltage. I got 35V caps from radio
shack for 1.59 each. You just need to solder out the bad ones and then
put the new ones in and solder. Remember that the negative end goes on
the side with the bold black part of the circle on the system board.
Then just cut off the extra ends of the capacitors. If you are capable
of doing this yourself, you will spend at most 6 dollars instead of
however much a technician costs.
12/19/2014 9:14:50 AM •
Samsung...
Answered
on Dec 19, 2014
Samsung 40inch LCD tv doesn't turn on for some
To all who are having power supply issues: Samsung is now acknowledging
a problem with the faulty capacitors. I called 1 800 726-7864 and they
said they would repair certain out-of-warranty TVs if the problem is
related to the capacitors. I just called and they are sending a service
rep out to diagnose the problem
3/4/2014 10:31:34 PM •
Samsung...
Answered
on Mar 04, 2014
Thanks for taking my question,my sister gave me her 40"
Clicking noise and tv does not start. Most of the times it is the power supply board which is found defective. But I have found Main board also responsible for this problem. Please consult some qualified technician.
12/29/2013 5:49:30 AM •
Samsung...
Answered
on Dec 29, 2013
Motherboard
Mother board burnt means you have to replace it. But before you must see that the other board are ok.
12/29/2013 5:36:35 AM •
Samsung...
Answered
on Dec 29, 2013
Rainbow screen
Hi Metthew,
Most probably the TCON board in your tv is defective. Please consult some qualified service technician. Most of the time the company service centers ask you to replace the entire LCD panel, which is an expensive affair. TCON board is a small part of the panel. and its job is to distribute the picture information across the LCD screen. Good luck.
12/29/2013 5:33:12 AM •
Samsung...
Answered
on Dec 29, 2013
