20 Most Recent
Samsung SCL901 Hi8mm Camcorder Questions & Answers
Samsung scl901 camcorder screen "rolls" on lcd
Possible that there is loss of sync from the signal and so it is unstable on both the viewfinder and the LCD display. This can be a fault on the main board- processing section. It can also be related to weak passive components or development of moisture. Leave the camera ON for few hours , place it on a warm surface - near to a table lamp and see if the fault changes. If so you need to keep using the camera often to keep the circuits active.
I Have a Samsung handy
You need
this cable or one that is labelled as USB to Mini USB.
http://www.amazon.co.uk/AmazonBasics--Male-Mini-B-Cable-Meters/dp/B001TH7GUK/ref=sr_1_1?ie=UTF8&qid=1307984144&sr=8-1
http://www.play.com/Electronics/Electronics/4-/5889160/USB-2-0-5-Pin-Mini-B-Cable-1-8-Metres/Product.html?searchtype=allproducts&searchsource=0&searchstring=mini+usb&urlrefer=search
Free manual for a Samsung
You can download and print the instruction manuals in PDF format by clicking these links:
SCL906
SCW61
Please note: Adobe PDF Reader is required to view this manual.
Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using
FixYa.
What do L.EMG and R.EMG mean and why do they prevent me from any activity with my camera?
The errors you are getting are "reel" errors. One or both of the tape reels are not turning during tape movement and the camera is shutting down to protect itself and your tape. In this model this problem is usually caused by the take up reel shaft being bent due to improper insertion of the cassette although this may not be the case. Please inspect both the takeup and supply tape reels and insure they are in correct alignment, if not, a gentle push to one side or the other will place them back in operating position. Good luck to you.
Joe Weibel
CustomElectronics.Org
I have a samsung SCL860
SOUNDS LIKE YOU BLEW A INTERNAL FUSE TO THE MAIN BOARD. IT IS VERY COSTLY AND IS HARD TO DO.. SORRY YOU MUST GET A ANOTHER ONE. YOU MIGHT WANT TO CHECK FOR A CANON ?
Copying tape
Make sure that all of the pins in the S Video cable are not bent. I've seen that cause the video not to work.
Does it still do the same thing if you were to use a standard video connection to your video player?
