20 Most Recent Samsung Digimax A503 Digital Camera Questions & Answers
Pictures at night have blotchy circles on
If you are using digital zoom, not optical, the image processor in the camera has to extrapolate data from the surrounding pixels. In good light, this gives acceptable results, but at night when (as you may have noticed) it is darker, it encounters problems and does the best it can.
9/9/2017 12:43:00 PM • Samsung Digimax... • Answered on Sep 09, 2017
Digimax A503 going into AUTO mode and running down BRAND NEW BATTERIES before they can be used
Attempt to restore camera electronics to factory defaults. If you cannot do so, contact Samsung tech support for assistance/input. If they cannot help they you have a dilemma/ replace or repair? But if not an expensive camera the choice is clear.
9/8/2017 3:43:53 PM • Samsung Digimax... • Answered on Sep 08, 2017
Camera has a black screen when turned on
In some cases there are only oxidized battery contacts, to treat with a little bit sillicon grease on the battery contacts gives a long lasting protect against. moist., otherwise there could bad soldering but in practice i have never on camera,s have problems with it BUT another suggestion are the little motors to operate the diaphragm and zoom mechanic can be the problem if its hanging and if one of the motors is hanging there could be a miss timing and then the electronical protection turns it off off. was my first Samsung experience with a camcorder of the brand 23 years ago there could be a dirty mode select switch or little microswitch on it, but in most cases the batteries.
8/2/2017 8:57:29 AM • Samsung Digimax... • Answered on Aug 02, 2017
Problem saving images to memory card
Make sure you have set the camera to use the memory card. It wont automatically use it, default is internal memory.
5/18/2017 11:52:56 PM • Samsung Digimax... • Answered on May 18, 2017
Broken battery door
Gaffer tape.
5/9/2015 10:43:28 AM • Samsung Digimax... • Answered on May 09, 2015
3answers
My samsung digimax 503 has a white screen!
Oh my gosh this really works! Our screen went white, we hadn't dropped it or anything. The camera still worked fine but we just couldn't see what we were taking a picture of. We tried this solution and now we can see the picture through the screen perfectly. THANKS for posting this!
7/20/2014 5:58:53 PM • Samsung Digimax... • Answered on Jul 20, 2014
Any lamp power but no ready to lcd on
Sorry, not worth repairing - too old.
7/5/2014 6:52:13 PM • Samsung Digimax... • Answered on Jul 05, 2014
I can't switch on my camera so can you tell me
The manual says: if the camera does not turn on after you have inserted battery, lease check whether the battery are inserted with correct polarity (+/-)Never use unnecessary force to put the battery in the chamber.If you are not sure the battery is still ok, try two other batteries type AA. The camera will work with non rechargeable alkaline batteries and will work with rechargeable Ni-MH batteries.When the battery chamber is open, please check if the metal connection point are not corroded and clean.You still can find the manual online and the thing I describe here is on page 8
10/29/2013 11:32:59 AM • Samsung Digimax... • Answered on Oct 29, 2013
Card is locked
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
9/3/2013 8:45:50 PM • Samsung Digimax... • Answered on Sep 03, 2013
2answers
My Digimax A503 camera keeps coming up on screen
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
4/26/2013 10:05:28 AM • Samsung Digimax... • Answered on Apr 26, 2013
My pc wich has windows 7 can't detect my samsung digital camera a503 i need a fix because i have tried everything
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
4/18/2013 9:22:45 PM • Samsung Digimax... • Answered on Apr 18, 2013
Need driver for samsung CAMERA digamax A503
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
2/23/2013 4:56:27 AM • Samsung Digimax... • Answered on Feb 23, 2013
How to get Protected removed
See page 43 of this manual.
2/23/2013 4:55:30 AM • Samsung Digimax... • Answered on Feb 23, 2013
Need operating instructions
You may download a copy of the manual here.
2/23/2013 4:54:33 AM • Samsung Digimax... • Answered on Feb 23, 2013
How do I take the camera off macro mode? The
See page 16 of this manual.
2/23/2013 4:53:52 AM • Samsung Digimax... • Answered on Feb 23, 2013
Where does the memory card go
See the illustration on page 8 of this manual.
2/23/2013 4:53:03 AM • Samsung Digimax... • Answered on Feb 23, 2013
Samsung Digimax A503 Digital Camera Logo
126 questions posted
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
DigiMax Samsung
  • DigiMax Samsung
Most Popular Question
locked cam
  • Cameras
