20 Most Recent SanDisk Sansa c150 MP3 Player Questions & Answers
2answers
Not enough space message, etc.
It's not a hard work that you can have a try powerful program Leawo Tunes Cleaner. Leawo Tunes Cleaner is a professional duplicate music remover. Step 1. Run Tunes Cleaner and Scan Duplicate Songs After kicking off Leawo Tunes Cleaner for Windows, click the "Clean-up Duplicates" entry. The program provides 2 duplicates scanning modes: Quick Scan mode and Deep Scan mode. Select one of them to scan duplicate songs. Step 2. Add Music Files for Duplicates Removing You could delete duplicate songs in iTunes music library by directly clicking "Scan iTunes" button or click "Add"button to load music files for duplicates removing. Or you could directly drag music files from your local folder to the software for duplicates removing. Step 3. Start Deleting Duplicates After loading source music files, click the "Scan" button on the upper-right corner to start scanning duplicates. The program would display all duplicates clearly and suggest what to remove. You could decide which duplicates to delete by checking them and then click the "Remove" button to remove duplicate songs. For more details, check: How to Delete Duplicate Songs tunes-cleaner-scan-result-gwujvob1wsqcwi5j4bnkubbk-3-0_1.jpg
4/24/2019 6:31:39 AM • SanDisk Sansa... • Answered on Apr 24, 2019
0answers
WIERD!
Be the first to answer 5/30/2017 7:45:03 AM • SanDisk Sansa... • Posted on May 30, 2017Be the first to answer
0answers
Mp3
Be the first to answer 4/17/2017 9:12:03 PM • SanDisk Sansa... • Posted on Apr 17, 2017Be the first to answer
I just bought the usb
Make sure it is the right thing.
I tried to use an extension cable for
mine and It won't work with it.
I don't understand it!
No ext fine, use ext no fine.
It could be the wrong cable/connector.
PLEASE RATE YOUR ANSWER
8/13/2011 4:12:05 PM • SanDisk Sansa... • Answered on Aug 13, 2011
MTP Format Mismatch DB.
fomatted without software know i cannot updae with new songs .display showing icons without any information
2/10/2011 1:06:39 PM • SanDisk Sansa... • Answered on Feb 10, 2011
I own a Sansa 2GB
Try plugging it into your pc go to my computer click on your device go into the music file right click and ddelete away.
1/28/2011 10:45:42 AM • SanDisk Sansa... • Answered on Jan 28, 2011
When i enter the USB into the computer i cant put
Use the supplied Sansa Media Converter program to convert and transfer pictures (and videos). If you don't have the SMC, you can download the Windows version from
http://www.megaupload.com/?d=3IPZO6Q0
1/26/2011 10:24:19 PM • SanDisk Sansa... • Answered on Jan 26, 2011
C150 as not working what's solution?
Check the orange "Hold" switch on the left side of the Sansa C150, if you cannot turn on the MP3 player or if none of the buttons is working. When the "Hold" switch is up, the buttons are disabled. Slide the "Hold" switch down to activate the buttons again.
Press and hold the "Power" button until the LCD screen lights up when turning on the MP3 player. Pressing the button quickly does not turn on the device. The "Power" button is located on the front of the device, under all the other control buttons.
Replace the AAA battery, if you cannot power on your MP3 player. To replace the battery, remove the battery cover from the back of the device by pressing in on its tab and pulling it off. Remove the old battery, insert the new battery and replace the cover. One AAA battery provides approximately 15 hours of power for your Sansa C150.
Change the backlight settings to conserve battery life. This is useful if you find the battery loses power quickly during normal use of your Sansa C150. To change the backlight settings, choose "Settings" to bring up the "Settings" menu. Select "Display," "Backlight" and then a shorter backlight time. The backlight will shut off after a period of inactivity that matches your backlight setting.
5
Review your music purchases to understand what rights you've purchased to the content, if you are unable to play a track back on your Sansa C150. When you purchase music, it comes with certain rules for how you can store and play it. You may not have paid for the right to transfer the song to a portable media player.
6
Reset the Sansa C150 if it acts erratically or if you have other problems. To reset the device, open the "Settings" menu and choose "Reset All." Choose "Save" to finish restoring the MP3 player to its factory default settings. If you decide not to reset the device during this process, select "Cancel" instead of "Save."
~KenjiFox
1/7/2011 12:32:57 PM • SanDisk Sansa... • Answered on Jan 07, 2011
I need the instruction manual
You can download manuals from the manufacturer's web site at
http://www.sandisk.com/sandisk-support/warranty-and-user-guides
11/7/2010 12:31:45 AM • SanDisk Sansa... • Answered on Nov 07, 2010
I want the instruction manuel
11/1/2010 4:19:01 PM • SanDisk Sansa... • Answered on Nov 01, 2010
Sansa c150
hello
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
8/29/2010 9:00:59 PM • SanDisk Sansa... • Answered on Aug 29, 2010
2answers
How do i format my sansa c150 mp3
go to settings then you should find format them click yes to confirm it.
8/27/2010 2:44:22 AM • SanDisk Sansa... • Answered on Aug 27, 2010
ScanDisk Sansa C150- ScanDisk Logo blinking and can't do anything
my mp3 player don't work properly..
when i plug mp3 players in my pc it work properly... after that when i unplug it my mp3 player doesnot work upto now.
when i switch on that it will display only scandisk logo.. then that it will not work.
then to switch off that i should take out battery.. you have any solution..
after that the pc also don't detect that player
8/5/2010 3:31:18 AM • SanDisk Sansa... • Answered on Aug 05, 2010
How to fix frozen c150
let it run out of battery eventually it will turn off
7/19/2010 3:30:00 PM • SanDisk Sansa... • Answered on Jul 19, 2010
The disc for my sansa c-150 does not regester when
got to sandisk.com and download the software haha
7/16/2010 2:46:21 PM • SanDisk Sansa... • Answered on Jul 16, 2010
I need driver for pc for sansa c150
http://www.sandisk.com/sandisk-support/driver-download-wizard
7/8/2010 9:59:03 PM • SanDisk Sansa... • Answered on Jul 08, 2010
Hi i have a scandiskc150 but the pc does not register it
You can download drivers from the manufacturer's web site at http://www.sansa.com
4/30/2010 12:07:12 AM • SanDisk Sansa... • Answered on Apr 30, 2010
SanDisk Sansa c150 MP3 Player Logo
133 questions posted
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
Sansa SanDisk
  • Sansa SanDisk
Most Popular Question
need instruction manual
  • Audio Players & Recorders
