20 Most Recent Sceptre X20g-Naga III 20.1" LCD Monitor Questions & Answers
0answers
0answers
0answers
Display appears for 1 second
Did you open it up and inspect to see if you can see any caps with bulging tops, check the 5v and 12~16vdc voltages?
If you are going to DIY and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SCEPTRE and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
11/1/2010 3:24:19 AM • Sceptre... • Answered on Nov 01, 2010
Sceptre monitor blackscreen x20g naga II not sure
Inpsect the power supply/inverter caps and voltages first, read my guides.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Please post back what you find.
10/25/2010 6:28:14 PM • Sceptre... • Answered on Oct 25, 2010
My monitor has shifted 90 degrees so that the top
press the button menu and select the rotation adjustment.
10/5/2010 3:01:10 AM • Sceptre... • Answered on Oct 05, 2010
Got a sceptre x20 and
More likely to have power supply problem due to bad caps, that will be the first thing to check.
If you are going to DIY and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also.
9/30/2010 12:03:34 AM • Sceptre... • Answered on Sep 30, 2010
Monitor takes forever to "wake up" once its on
The monitor is this old will more likely to have bad DC filter caps in the power supply by now. Does it do the same with other PC?
9/28/2010 3:42:01 AM • Sceptre... • Answered on Sep 28, 2010
Why does the Little Green Light on the front of my
The monitor is not getting any "signal" from the video-card.
Check that the video-cable is connected to both the monitor and to the video-card.
Try connecting the monitor to a different desktop/laptop,
to see if the monitor works "elsewhere".
Try connecting a different monitor to your desktop, to see if the video-card is the problem.
9/18/2010 2:06:45 AM • Sceptre... • Answered on Sep 18, 2010
Power lite goes on and off,and there is apopping
Hi there this mean the your monitor had an over flow of current which damage the monitor you will need to identify which component is damage and replace it. Here is a link with can give you step by step guide to open and check for the damage part.http://www.bit-tech.net/hardware/2006/03/20/how_crt_and_lcd_monitors_work/5 or you can replace the monitor if you choose to.
6/29/2010 6:29:39 PM • Sceptre... • Answered on Jun 29, 2010
Monitor says "Out of Range"
This normally happens when display resolution is changed to higher resolution and cannot be compatible/displayed by monitor. Either plug in another monitor and lower down resolution or Press F8 and go to advanced boot option and start your computer in safe mode and try changing display resolution. If it still doesn't works and you have the drivers for you display adapter (video card) then uninstall display adapter from device manager by booting in safe mode. Once you get to normal boot mode reinstall drivers for display adapter.
6/5/2010 5:10:19 PM • Sceptre... • Answered on Jun 05, 2010
2answers
My Sceptre monitor x20wg-nagall\r\npower light
first check the cable ...there can be always something wrong with them ...second..to be sure that the monitor is to blame ...hook another one to the computer and see if it works...also ...you may tell this if the actual logging sound is heard when you open it ...but even in this case the computer nay be ok ..and you just messed up the video card ...setting s..or the video-card itself....so ..either trying another monitor(even an old one ..just to see if it is th monitor to blame or the computer ) or try the monitor in another computer ...(if you have a laptop you can hook it as second monitor ,, and press Fn -F4 to activate it ..)
i fthemonitor turns up to be ok ...the issue is in the video card ...
first open and see if the card is proper inserted in the slot...push it down a little ..or get it out and insert it again ) ..if this will not brink it back ...try the on board card ...if the computer has one ...but for this to work you have to remove the pci one ..) ...there may be the case thet you tried some settings that the computer do not support on the card ..and now you will actually need to insert in the on board card ...and remove the video driver ..insert the other card again ...and reinstall the driver ...I did had this kinda problem with a video card ..and I meesed some settings on it ..and it shows up black after reboot..removing the driver it was te only way out than ...and my lack was tat I had a on board card ...if you do not ...and the monitor seam ok ...you will have to try to reinstall it ..I mean the computer ..
4/24/2010 4:14:56 AM • Sceptre... • Answered on Apr 24, 2010
I have a sceptre x20g naga III screen goes blank
if you have the warranty, return it and get a new one free. ok
2/19/2010 12:24:00 PM • Sceptre... • Answered on Feb 19, 2010
3answers
X20G-Naga III screen goes blank after 1-2 secs
FIXED!
Device : Spectra X20WG-Naga
Problem : monitor comes on then flickers then goes off
solution: Replace Capacitor C101 (150uf, 35V) and Fets U101 and U102 (4511GM)
Comments: This is a common problem with this monitor.
I’m happy to help further over the phone at https://www.6ya.com/expert/paul_0af9b1d5c0eb4fc3
1/18/2010 5:30:13 AM • Sceptre... • Answered on Jan 18, 2010
Sceptre X22 Naga Will not power up.
Start looking at the power supply for bad caps, see some example of a couple yeras old monitors that failed due to cheap caps being used: http://s807.photobucket.com/home/budm/allalbums
1/8/2010 5:07:17 AM • Sceptre... • Answered on Jan 08, 2010
When on its shuts off by it self after a few
rons1photogr, You will need to fix thermal intermittant solder joint and /or bad electrolytic filter capacitors on printed circuit board called "switch-mode-power-supply"/"CCFL inverter supply"???? Software can't fix this problem!!! Hardware refurbistment only. READ, READ, READ, more stuff in my profile on black screen repair s and or other options open to you. 12fixlouie
1/5/2010 4:02:07 AM • Sceptre... • Answered on Jan 05, 2010
Need video driver
Just go to this link for the same.
http://www.opendrivers.com/search.php
Thanks
Abhay Singh
11/24/2009 12:31:26 PM • Sceptre... • Answered on Nov 24, 2009
Comes on for a few seconds, then goes blank. Power
fried repir or replace
10/31/2009 9:01:14 PM • Sceptre... • Answered on Oct 31, 2009
Sceptre X20g-Naga III 20.1" LCD Monitor Logo
42 questions posted
Top Sceptre Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Sceptre Computers & Internet
Most Popular Question
monitor takes forever wake up once its
  • Computers & Internet
