20 Most Recent Siemens WTXD5300US Electric Dryer Questions & Answers
What is causing my electric dryer to stop running after 5-10 minutes
I presume that after it has "cooled" it starts and runs again? If so, the air circulation, perhaps the vent is clogged and needs cleaning. The high heat protection device is "cutting out" when the temperature gets too high to prevent disasters.
4/10/2015 3:12:01 AM • Siemens... • Answered on Apr 10, 2015
0answers
Really Bad Squeeky Noise
It could be a squeal from the dryer belt. It could be from a belt that has gotten loose, like you hear on a car sometimes when it first starts up, but usually they don't get loose. They just break. Maybe something has gotten jammed between the dryer drum and the interior of the dryer making it hard for the belt to turn the drum and so it is squealing. Does the drum turn by hand without too much force and without squealing?
2/11/2014 1:56:10 AM • Siemens... • Answered on Feb 11, 2014
0answers
Burning smell
Be the first to answer 11/13/2013 7:15:20 AM • Siemens... • Posted on Nov 13, 2013Be the first to answer
0answers
0answers
Thermal fuse
Be the first to answer 10/22/2013 6:01:43 AM • Siemens... • Posted on Oct 22, 2013Be the first to answer
Repair a semens wtxd5300us dryer thermal fuse
Buy a new one! You sound like you do not know what you are doing.
9/28/2012 10:36:50 PM • Siemens... • Answered on Sep 28, 2012
No heat while running.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
9/10/2011 3:52:46 AM • Siemens... • Answered on Sep 10, 2011
0answers
SIEMENS WTXD5322us Electric Dryer no
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
4/10/2011 1:52:45 PM • Siemens... • Answered on Apr 10, 2011
My siemens electric dryer will not start a cycle.
One is a thermal limiter that operates the heating element and the other is a moisture sensor.
Check to see that the door switch is operating properly with an ohmmeter (with the power disconnected, of course).
2/21/2011 2:00:09 AM • Siemens... • Answered on Feb 21, 2011
Siemens dryer has a extra swishing sound like
Is your dryer new?
if its isn't then probably that its ball bearings inside is started to end its service life or the belt begins to deteriorate and the drum touches the housing.
if its new, then probably that there is something getting loose inside or some foreign objects get inside the drum (e.g. moneys, pens, etc.).
12/29/2010 6:12:14 AM • Siemens... • Answered on Dec 29, 2010
My siemens dryer runs, but does not dry at all.
Yes, it could have ...
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
5/6/2010 4:01:27 AM • Siemens... • Answered on May 06, 2010
Dryers Logo
32 questions posted
Top Siemens Dryers Experts
vince
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
View Most Popular
Siemens Dryers
  • Siemens Dryers
Most Popular Question
siemens dryer extra swishing sound like
  • Dryers
