20 Most Recent
Siemens WXTS1301 Top Load Questions & Answers
Washing machine Siemens IQ800 - clear error
The
E34 error code on your Siemens IQ800 washing machine indicates a
door locking problem. Let's troubleshoot this issue step by step:
- Close the Door Properly:
- Ensure that the door isfully closeduntil you hear aclick. Sometimes, anexcessive loadof laundry can prevent the door from closing correctly.
- Check if there's any garment trapped between the door and the frame. Remove it if necessary.
- Restart the Program:
- After ensuring the door is properly closed,restart the washing machine program.
- If the error persists, proceed to the next steps.
- Check for Door Lock Issues:
- Verify that thedoor lock mechanismis functioning correctly.
- Inspect thedoor insurance wiringto ensure there are no loose connections.
- Look for any blockage or issues with thetriac doorin the control module.
Siemens a12-26 drawer cleaning
- Locate the tab on the softener compartment and lift it.
- Pull out the dispenser drawer by gently pulling it towards you.
- On the top of the dispenser drawer, you should see a locking mechanism. This mechanism is usually a small lever or button that you need to press in order to release the lock and allow the drawer to be removed.
- If you can't find the lever or button, consult the user manual for your specific model of washing machine, which should have instructions on how to remove the dispenser drawer.
- Once the dispenser drawer is removed, you can clean it and the interior of the machine.
Note: If you are unable to find the instructions in the user manual, you can also contact the manufacturer for assistance.
My Siemens IQ700 washing machine does not work
mens IQ700 Washing Machine Not Working.
Tell me Answer My Siemens IQ700 washing machine does not work
There could be many reasons why your Siemens IQ700 washing machine is not working. Some common issues include a lack of power, a malfunctioning door lock, or a faulty control module. Without more information about the specific problem, it is difficult to provide a definitive answer. I would recommend checking the user manual or contacting Siemens customer support for troubleshooting assistance.
