20 Most Recent
SMC : EZ Connect USB Cable Modem (NESMUP01) Questions & Answers
I need WIN 7 driver for smc 7003 ez connect usb
After navigating to SMC's website, I found the driver for your device, however windows vista/ windows 7 is not listed as supported, however, they did have a driver for
- Windows 98
- Windows 98 SE
- Windows NT4
- Windows Me
- Windows 2000 Professional
try using this driver and see if windows 7 will be able to use it.
If you have any questions please let me know!
Thanks,
Mike
Hi Guys ...
I will suggest to check the router settings and make sure TCP Port 1723, IP Protocol 47 (GRE) are
opened. Also make sure that the router has the PPTP enabled and
not firewall block the traffic. On the RAS server, check the DHCP
settings
Driver problem
drivers.myfreewares.com/driverdeveloper-1555-smc-download.html
MBP8,1 late 2011 new battery not working
You realize people reading this have no idea what this mumbo-jumbo means. Brett has no idea and he is the master of all masters in lateral thinking!
'make model (what it is)', plus a detailed description of the issue!
Wat is the smc networks use for
SMC Networks serves up networking equipment, with or without wires. The company makes wireless local area network (LAN) devices designed for use in homes and businesses.
How to solve USB device not recognized ?
different USB port. There are usually 3 or 4 of them. If you can, format the USB drive (if you have nothing on it or already have copies of what is on it). It will take 10 seconds, but will wipe all data. It should be recognized then.
When trying to use the
look for a windows xp driver file on the included program compact disc that may need to be installed before you use the included program.
