20 Most Recent
Sony Ericsson Z520a Headset Headset Questions & Answers
Problems with connectivity. No signal.
I am having this problem as well.
A repair guy told me its probably the antenna's connections to the circuit board, but he couldn't fix it.
I'm searching for a solution...
Screen Is White.
I had repaired about 10 Z520a that have the same symptom as yours.. It is because the Flex cable damage. The LCD are connected using this flex cable. You can purchase one from shop or at Sony Ericsson shop.
My cell has some white lines in the screen
i called sony ericsson & they told me i should try buying a dcu-60 usb cable to hook up the phone to the computer & use the update service on the s.e. site. we'll see if it works, i just ordered one off the 'net for about 7 us dollars. worth a try for under ten dollars.
Sony Ericson 250i Headset not recognised
The wire to headsets can get damaged (usually not visible from the outside, as the wires inside the covering can be very delicate, to keep the size of the wire down) from throwing them in the pocket, purse, etc. Try a set from a friend to make sure the device is still working itself.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
