20 Most Recent
Symbol LS 4278 Barcode Scanner Questions & Answers
What type of battery does a ls4278 barcode scanner take
When creating a
gmail account login, a
Google account will be automatically created. From this account, you could access other Google products and services, such as
YouTube,
Google Drive, and
Google Plus
Gmail new account
Creating a Gmail account is quick and easy. You can start easily with 3 steps:
- Try to think about a username.
Your username will become your new Gmail email address. Have a backup or two handy in case your desired name is already taken. If your username is not available, you will be given several related options, or you can try a different one.
- Fill out the rest of the required information.
You provide other required info including: your first and last name,...
When I scan an item with the LS4278 I receive 4
Basketball Games Sports fans will love our huge selection of basketball games. You can play quick arcade challenges or in-depth simulation challenges. Choose your favorite court, pick a player, and get ready to shoot some hoops! Our collection puts you in control of star NBA players, street ball athletes, and newbies. You'll be challenged to make 3-pointers, score huge slam dunks, and beat your opponents in 4 quarters. Exciting sports challenges are waiting for you!
Our collection is full of countless types of sporting bouts. You can play prison basketball, a 3-way shootout, and even Olympic challenges! All of our basketball games feature colorful graphics, easy-to-learn controls, and highly addictive gameplay. You'll be completely immersed into high-octane sports adventures. Our collection will fire you up, put your skills to the test, and give you the chance to become an NBA star. Sink some 3-pointers today!
Play game now free: http://basketballgames.io/
Why i cannot scan 1 digit number
Did you make the barcodes using Code 39 or 3 of 9? If so, the scanner defaults to reading between 2 and 55 character Code 39 barcodes. Go to the Motorola Solutions support portal and search for Article ADC-00404
portal motorolasolutions com. Print the article and scan the Code 39 Any Length barcode. Once this is done the scanner will read all Code 39 barcodes.
When I scan a barcode with the Symbol LS 4278
There was probably some kind of ADF Rule applyed, please scan the barcode Set All Defaults and Erase All Rules from ADF Chapter in the manual for LS4278 aailable here http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6983404apdf&sliceId=&dialogID=190394003&stateId=1%200%20190388491
My ls4278 is not lighting.
The most unlikely scenario is that all the bases are defective. If you power your PC off every night, you should purchase a power supply so the scanners can continuously charge. Another issue may be that you need new batteries (also unlikely if they stopped working at the same time). Also try swapping scanners and bases (one scanner from one base and place it with another base) make sure you firmly place the bottom of the scanner in the base to verify there is a good connection with the charging pins. We are here to help if you have further questions.
Tech Support Barcoding Technical Support
When my scanner ls4278 is on the cradle it has a
I was also unable to find a solution for you. There are only supposed to be 2-leds in the cradle, 1-green and 1-amber. Maybe it is a battery temp fault, and it has somehow been misread. If you have another docking station and another gun, try swapping them to see where the fault lies. If on the good station the gun shows the same error, you know the fault it with the gun, not the cradle. Hope this has helped!
3 Beeps after trying to scan
If you are receiving three quick beeps (all the same tone) before a scan the battery is low. If the scanner is more than two years old the battery may need to be reconditioned. It is recommended the battery be reconditioned once a year. The latest revision of the LS4278 manual is here:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6983404apdf&sliceId=&dialogID=134112767&stateId=0%200%2014115220
Print page 28 of 414 and scan the Battery Recondition barcode. The scanner will discharge the battery then charge it up again. It goes through this two times so you need to leave it on the charger a while for this process to complete. Hopefully this will resolve your issue. If not, you may need a new battery.
If the beeps are low, medium, high the procedure above still may work, but you might want to call Motorola for assistance. Sometimes hearing the beeps helps to diagnose the problem.
Will not pair with android device, android tells me to enter code into the scanner.
Check out the Zebra support article that contains the barcodes to be scanned when prompted
to enter a pin code:https://portal.motorolasolutions.com/Support/US-EN/Resolution?solutionId=5969&redirectForm=search&searchQuery=%3FsearchType%3Dsimple%26searchTerm%3DLs4278%20open%20bluetooth
There is a link in the article to a Word document that contains screenshot and all of the necessary barcodes.
