20 Most Recent Targus USB Ultra Mini Keypad Keyboard PAUK10U Questions & Answers
0answers
4answers
Driver for PAUK10 keypad with Mac OS 10.2
Hold down the NumLock key for 4 seconds or more and then it should work.
Also try holding down the NumLock key before you connect it.
2/4/2014 7:06:19 AM • Targus USB Ultra... • Answered on Feb 04, 2014
7answers
My numbers aren't working and my num loc is on
i got it!! hold down the 2 shift keys for a few seconds then bamm!!
12/7/2013 9:18:58 PM • Targus USB Ultra... • Answered on Dec 07, 2013
None of the keys are
Try a regular usb keyboard to make sure it is functioning properly
If so may need to replace keyboard
Also try a different usb port
6/25/2011 7:53:53 PM • Targus USB Ultra... • Answered on Jun 25, 2011
My Tarsus Keypad works fine
Not to be smart, but the same thing was happening to me and I realized the Num Lock needs to be activated on the keypad AND on your laptop. I did not have it activated on my laptop and I was realizing the same problems.
3/20/2011 2:56:40 PM • Targus USB Ultra... • Answered on Mar 20, 2011
Push Num Loc get 5, push BS get 6, push 6 get \,
semd to be an error keyboard mapping, select your correct language
3/3/2011 10:40:10 PM • Targus USB Ultra... • Answered on Mar 03, 2011
I do not know what BS, Ins keys are for on Targus
Ins key is for insert. Works great in spreadsheets.
3/1/2011 1:17:08 AM • Targus USB Ultra... • Answered on Mar 01, 2011
0answers
My numbers 1 and 3
download new driver
10/24/2010 10:07:03 AM • Targus USB Ultra... • Answered on Oct 24, 2010
I have a targus external
You can try this:
- When your Targus keypad is disconnected press and hold the Num Lock button.
- Connect your Targus Keypad USB cable to your mac USB port while still pressing and holding the Num Lock key.
- When the Num Lock green LED light goes on, wait for exactly at least three seconds then release the Num Lock Key.
- Now it shouldn’t Beep and it will work fine in programs.
Hope this helps.
Waiting your comments.
7/17/2010 10:41:02 PM • Targus USB Ultra... • Answered on Jul 17, 2010
Whenever I hit a number key it turns on and off
This keypad is meant for mass number data, not as a joystick replacement I'm afraid.
Did you install any software that came with it? If so, try removing it Normally you don't have on-screen NumLock messages, so this must be something extra.
It clearly wants to be used for number entry. Perhaps it has some switch to change it's behavior, either physical, or in software?
3/12/2010 7:51:08 PM • Targus USB Ultra... • Answered on Mar 12, 2010
3answers
I have this exact targus
Hi, Try to put a cloth under the keypad to avoid for any much more impact when you try to hit any key.. As the pad was still need it take sometimes to get the pad work freely to its contacts. Hope this initial info helps
10/14/2009 3:29:12 PM • Targus USB Ultra... • Answered on Oct 14, 2009
Where is the equal sign.
Usually the = sign is substituted with the * sign on the number pad.This symbol is above number 9 on the right side number pad.
9/15/2009 9:03:32 PM • Targus USB Ultra... • Answered on Sep 15, 2009
2answers
19 key Numeric keypad with 2 usb ports
You better consult your hardware manual.
If there is no manual Try checking your regional language selection in control panel. Check your MS word configuration go to: Tools > Options Check your settings for keyboard or input device.
9/13/2009 1:42:37 PM • Targus USB Ultra... • Answered on Sep 13, 2009
My keyboad isnt working
check the connecting cable and pin
1/29/2009 1:11:08 AM • Targus USB Ultra... • Answered on Jan 29, 2009
My number keys arent working
Try holding down the shift key again for 8 seconds and read the window to cancel the filter keys.
As for your numbers not working, there is a NumLock [number lock] key on your keyboard. Try hitting that and see if your numbers work.
Hope this helps.
shibumi
1/26/2009 4:23:25 AM • Targus USB Ultra... • Answered on Jan 26, 2009
Need to find a download for this
user giude HERE
7/26/2008 1:20:45 PM • Targus USB Ultra... • Answered on Jul 26, 2008
Numbers not working
On keyboard press number /try again restart the computer and try again.
1/8/2008 7:52:58 PM • Targus USB Ultra... • Answered on Jan 08, 2008
Targus USB Ultra Mini Keypad Keyboard PAUK10U Logo
Popular Tags
32 questions posted
Top Targus Computers & Internet Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Targus Computers & Internet
Most Popular Question
tarsus keypad works fine
  • Computers & Internet
