20 Most Recent Maytag MTB1895AE Top Freezer Refrigerator Questions & Answers
How do I remove glass shelf from refrigerator
Tilt shelf up to almost a 45 degree angle and unhook from back of fridge.
10/19/2013 6:32:14 AM • Maytag MTB1895AE... • Answered on Oct 19, 2013
How do you remove the plastic control housing so I
In the front of that housing between the dials is a 1/4 inch hex headed screw and also one about 6 inches back from that one is a second one. remove those screws and the control panel will come down.
GENE
8/27/2011 2:49:58 AM • Maytag MTB1895AE... • Answered on Aug 27, 2011
Both the refrigerator and freezer
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
8/19/2011 3:42:12 PM • Maytag MTB1895AE... • Answered on Aug 19, 2011
How to remove take glass shelf to clean trapped spills
lift the front nosing by prying with your fingernails up...it will roll in place allowing you to remove the glass
12/4/2010 5:17:01 PM • Maytag MTB1895AE... • Answered on Dec 04, 2010
Maytag ref MTB1895 warm on inside, air is circulating, clicking sound
we ll see how u need to check the defrost timer....
Before testing the defrost timer, unplug the freezer to avoid an electrical shock hazard.
A mechanical defrost timer controls the defrost cycle of the appliance. In older models, the timer runs continuously and roughly every six hours, shuts off power to the cooling system and sends power to the defrost heater. In newer models the timer advances only when the compressor or defrost cycle is running - an improvement for efficiency. As the timer advances, power to the heating element shuts off and power is restored to the cooling system. If the timer does not advance, the appliance will be stuck either in defrost or refrigerate mode, resulting in, respectively, no cooling or frost build-up.
The defrost timer is usually found behind the front grill of the freezer. It may also be found behind a cover plate inside the freezer, in the temperature control console, or behind the freezer near the compressor.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.
Test the timer for continuity using a multitester. Set the multitester to the ohms setting X1. The timer has four terminals. Locate the common terminal, it should be labeled "3" or "C". If the terminals are not labeled, determine which terminal coincides with the common wire in the connector plug; it is usually the white wire.
Once you have located the common terminal, touch one probe to it. Touch the other probe to each of the three remaining terminals. The multitester should display a reading of zero or near to zero ohms (which indicates continuity) for one pair of the terminals and possibly two pairs. The third pair of terminals should show no continuity (infinity).
Locate the timer switch and turn it clockwise until you hear it click. Now retest the timer as you did above. One pair of terminals should indicate continuity (possibly two pairs). At least one pair should give a reading of infinity. Note however, one of the pairs that showed continuity in the first test should now read infinity and one pair that read infinity should now show continuity. If the defrost timer does not pass these tests, it is likely that it should be replaced.
Before testing the defrost heater, again make sure u unplug the freezer to avoid an electrical shock hazard. The defrost heater is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear or bottom inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. There are three primary types of defrost heater elements; exposed metal rod, metal rod covered with aluminum tape or a wire coil inside a glass tube. All three elements are tested in the same way. The heater is connected by two wires.Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Test the heating element for continuity using a multitester. Set the multitester to the ohms setting X1. Place a probe on each terminal. The multitester should display a reading somewhere between zero and infinity. If the reading is not between those two extremes the heating element should be replaced.
this is how u check the thermostat..... again Before testing the defrost thermostat, unplug the refrigerator to avoid an electrical shock hazard. Some defrost systems use a thermostat (a bi-metal switch) to prevent the defrost heater from overheating. The switch is normally closed. During a defrost cycle, the defrost heater causes the metal alloy in the switch to warm and as it does it curls back and breaks the circuit. As the metal cools, it makes a circuit again and the defrost heater starts heating again (as long as the defrost timer is in the defrost cycle). A defective thermostat can prevent the defrost heater from coming on or allow it to overheat which could result in heat damage or fire. The panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. On some older top freezers it is necessary to remove the plastic molding to access the freezer floor. Removal of that molding can be tricky -never force it. If you decide to remove it, you do so at your own risk - it is prone to breaking. Try warming it first with a warm, wet towel. The thermostat is connected by two wires. The wires are connected with slip on connectors or a wiring harness. Firmly pull the connectors or harness off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced. Test the thermostat for continuity using a multitester. Set the multitester to the ohms setting X1. Place a probe on each terminal. The multitester should display a reading of zero when the thermostat is cold and a reading of infinity when it is warm (40 to 90 degrees F depending on the model). If the thermostat does not pass this test it should be replaced. with regard to the parts incase u need a replacement..... check out the below link.... http://www.repairclinic.com/GE-Freezer-Parts?s=b3a3c221
9/1/2010 10:37:15 AM • Maytag MTB1895AE... • Answered on Sep 01, 2010
Why is the refrigerator making
There is a cooling fan in the back that needs to be cleaned and you need to check for any lose parts. Vaccum cleaner works best. You may have to remove a few screws and a cover to get to the fan...pretty simple to do.
8/13/2010 11:16:54 AM • Maytag MTB1895AE... • Answered on Aug 13, 2010
Fridge worked fine, lost powere to house, hooked
is the gen-set large enough amperage wise to run the unit,if not it may have starved the ptc overload contactor on the refrigerator and overheated it and kicked it out,it should reset itself unless it got toio hot and was ruined, another issue is,if the T.H.D.(Total Harmonic Distortion) of the gen-set is over 12%T.H.D. these electronics may not operate properly either and kick out,check with both manufacturers for limits there also
7/18/2010 4:48:20 PM • Maytag MTB1895AE... • Answered on Jul 18, 2010
I have a Zanussie cool wall with glass shelves,
do you have a model and serial number of this refrigerator?
2/6/2010 12:57:13 PM • Maytag MTB1895AE... • Answered on Feb 06, 2010
Water line hooked up to unit for icemaker but
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
9/12/2009 6:08:49 PM • Maytag MTB1895AE... • Answered on Sep 12, 2009
2answers
I have large droplets of ice on the freezer
sound like the gasket on the frzr door not sealing properly see where the gap is and get you hairdryer out and heat the gasket up then it should seal properly
8/26/2009 10:03:18 PM • Maytag MTB1895AE... • Answered on Aug 26, 2009
How do you install maytag "mbb1954g" ice maker plastic water line connection to the freezer?
To connect the water supply using a plastic hose kit to the MBB1954G UNIT, you can follow these steps: Turn off the water supply valve under the sink. Remove the old hose from the water supply valve and the back of the refrigerator. Attach the new plastic hose to the water supply valve and the back of the refrigerator. Make sure the hose is not kinked or twisted. Tighten the fittings with an adjustable wrench. Turn on the water supply valve and check for leaks. Here is a video tutorial that demonstrates how to install a water line to an ice maker or refrigerator using a 5 foot hose with 1/4 inch compression fittings. INSTALLING ICE MAKER / REFRIGERATOR WATER LINE - using 1/4" compression hose (youtube.com)
2/15/2024 9:40:38 PM • Maytag... • Answered on Feb 15, 2024
Maytag 2 door fridge has only water for ice cubes. Is there a water filter for the ice?
you can add water filter. It is installed on supply line. go to Home Depot and pick up a refrigerator water filter kit with accessories.
10/19/2023 1:58:54 PM • Maytag... • Answered on Oct 19, 2023
I got some ice from the doors ice and water dispenser I heard the ice maker turn over then instead of water going into the ice maker to refill it began coming out the door water dispenser.
inspect the ice make to check for any sign of visible damage or misalignment, .and unplug the fridge and plug it again
8/23/2023 5:17:05 PM • Maytag... • Answered on Aug 23, 2023
Where is the defrost timer on Maytag top freezer RTD21E0CDL
Matthew...you sure you have the Model# right? Cuz Google comes up with Zip..Zilch with that #.? :)
8/15/2023 5:37:38 PM • Maytag... • Answered on Aug 15, 2023
My Maytag MZD2768GE frezzer side is forming ice on the bottom. Water is coming out of the lower vent.
Fridge/freezer freezing up- and no fan or air circulation: first check the defrost terminator thermostat it may have gone out. Thus not allowing the heating element to melt the ice. AT TIMES The fan usually stops working AND CAN MAKE FUNNY NOISES AS WELL due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature. May also need to check the defrost timer, The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. Or in the fridge compartment near middle top section. u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad? Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next. Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance.. Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS . Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit? ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area! THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required Freezer /fridge leaking water/ice frozen in fridge and or freezer, or leaks on floor Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out. Fix any gaps in the door seal.Pack out the seal underneath the areas where the door seal has the gaps. This can be done with a small strip of weather stripping, as shown here, or a bit of tightly rolled up paper under the door seal. Alternatively, you can heat the door seal up with a hair dryer to fix the gaps. This softens the door seal and allows you to stretch it. Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor. However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick. Another trick one can use is to connect a copper tube wire with one end going into the drain hole then attach the other end to the heater wrap it around heater a few times. That will take care of the drain problem when it comes to ice build up but not food build up. Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also. Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer. God is so good: so this is why I give free advice so please thank him not me. OTHER THINGS TO CHECK ARE THE DEFROST TERMINATOR AND THE HEATER ELEMENT FOR COBNTINUITY. defrost timer location defrost terminator-undefined-undefined-0_2.jpg door seals cracked-fridge-seals-undefined-undefined-1.jpg drain center drain holer-undefined-undefined-2.jpg drain hole freezer downside-undefined-undefined-3.jpg evaporator-fan-blade.1280x600-undefined-undefined-4_0.jpg
7/26/2023 8:07:17 PM • Maytag... • Answered on Jul 26, 2023
Does the Maytag Model: MSD2651KES have a drip pan underneath?
The Maytag Model MSD2651KES is a side-by-side refrigerator. It does not have a traditional drip pan underneath like some other refrigerator models. Instead, it uses a drain system to collect and channel condensation and defrost water. The condensation and defrost water from the freezer section of the refrigerator typically flow down through a drain hole and into a drain pan or trough located at the bottom of the refrigerator. This drain pan is usually not accessible from the outside and does not require regular maintenance or emptying. If you are experiencing any issues with water leakage or pooling around your Maytag refrigerator, it is recommended to check the drain system for any blockages or clogs. Ensure that the drain hole is clear and that the water can flow freely through the system. If you suspect a problem with the drain system, it is advisable to consult the refrigerator's user manual or contact Maytag customer support for specific guidance on troubleshooting and resolving the issue.
6/28/2023 2:44:00 AM • Maytag... • Answered on Jun 28, 2023
Oil coming from the inside of my Maytag refrigerator door?
Either the compressor is broken or is now compromised.The compressor needs to now be replaced for your fridge.
5/10/2023 7:12:14 AM • Maytag... • Answered on May 10, 2023
2answers
Water pooling at bottom, how do I find out why?
Water is pooling at the bottom of your refrigerator because the drain in the freezer is clogged, probably with ice. You need to turn of the refrigerator and empty the freezer. Remove the cover in the bottom of the freezer by first removing the back cover of the freezer and then the bottom cover. You will probably see it full of ice. Remove this ice by chipping, or if you have time, let it thaw. Then, located the drain in the back of the compartment below the coils, and thaw it. You can use a hair dryer for this. Eventually, you will see the water drain, and you can dry everything up and put it back together. You should have no more problems. If you do, then you need to look at testing the defroster.
4/24/2023 3:40:07 AM • Maytag... • Answered on Apr 24, 2023
Maytag MTB1895AE Top Freezer Refrigerator Logo
22 questions posted
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
  • Refrigerators
