20 Most Recent
Toshiba Satellite M55-S3512 Notebook Questions & Answers
I need windows 7 drivers
TENGO UNA TOSHIBA SATELLITE M55-S3512 Y NO CONSIGO EL DRIVER DE ALMACENAMIENTO MASIVO Y EL DRIVER DE VIDEO. ESTOY TRABAJANDO CON WINDOWS SEVEN (7). POR FAVOR AYUDA...
[email protected]
6/8/2016 6:53:04 AM •
Toshiba...
Answered
on Jun 08, 2016
Where can i find my drivers for toshiba A305-S6905
Try this linkhttp://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2205366&rpn=PSAG8U&modelFilter=A305-S6905&selCategory=2756709&selFamily=1073768663
1/26/2013 5:48:50 PM •
Toshiba...
Answered
on Jan 26, 2013
Bios password
you need to put flash or cd drive in start the bios..http://answers.microsoft.com/en-us/windows/forum/windows_7-security/how-do-i-unlock-my-windows-7-password/3a6b4ef9-c872-49e9-b122-12b2fefbf723
12/24/2012 5:52:07 AM •
Toshiba...
Answered
on Dec 24, 2012
Hi i need to download drivers
i need drivers for my toshiba satellite M55-S3512. other drivers i have found from the toshiba web site but only the given below drivers i could not find.
1. Mass Storage Controller
2. Video Controller
3. Video Controller(VGA Compatible)
any one help from where i can find these drivers.
thanks
12/24/2012 5:48:51 AM •
Toshiba...
Answered
on Dec 24, 2012
I need to take off the bios password
the bios password can be removed by toshiba, they have a master code which will remove the bios password. There is no generic master code that will remove this bios password. It is unique to each machines serial number and can only be removed by them. I am sorry but that is what you will have to do
Steven.
4/22/2010 8:53:42 AM •
Toshiba...
Answered
on Apr 22, 2010
Which usb ports are 2.0 speed on my m55-s3512?
Well, with the usual efficiency of Toshiba, I can't locate the M55 series laptops to lookup, the M50 does seem to be similar though and all the USB ports there are 2.0.
Easiest way? Find a new USB device (memory stick for example) and plug it into each port in turn. Give windows enough time to detect and install it, and if it's a USB1 port, you'll get a message saying "This device can perform faster in a USB2 port".
3/2/2010 12:23:14 AM •
Toshiba...
Answered
on Mar 02, 2010
My question was: By sheli_a_schm on Feb 11, 2010
Yup bad hard drive I would also say. Yes, you can just purchase another Hard Drive no problems. Yes you could install it yourself, & reinstall Windows. It isn't too hard. You just have to methodical and follow instructions. There are many tutorial on the 'net regards how to do it.
2/11/2010 10:43:36 PM •
Toshiba...
Answered
on Feb 11, 2010
Ave tried to use the recover disk 4 times now, and
If you reinstalled the Operating System and are still getting errors then it is a hardware issue.
From what you describe it sounds like your hard drive is failing. A failing hard drive will "lose" files out of nowhere and cause many "weird" errors because the lost files are usually system files needed for Windows.
2/11/2010 6:33:49 PM •
Toshiba...
Answered
on Feb 11, 2010
My mouse on my toshiba satellite M55 S 3512 is not
Hello, this is Mike. I'm sorry to tell you that despite being having dried up the water you spilled more than likely left mineral deposits on the circuits in your mouse which cause it to short out and not function. If you are using an external USB mouse I recommend replacing it. If it was the touch pad on the laptop itself I must recommend you attempt to use your warrantee to have it replace or if it has expired I suggest you bring your laptop to a certified technician and have it repaired. I hope this helped you.
1/19/2010 2:03:00 AM •
Toshiba...
Answered
on Jan 19, 2010
