20 Most Recent
Toshiba 100GB Laptop for Satellite 2400, A, M, P, Satellite Pro 6100, M, Portege M200, Tecra 9100... (GPOHDTS2400100R) Hard Drive Questions & Answers
CANT FIND HARD DRIVE DURING
Put the hard-drive in another PC and see if it works .....
And if it do then.....
the pc that showed the error could have a problem in the bios setting (press F2 to get the bios during boot to get to the bios setting....try to reset the bios setting to factory settings)....or you could have to perform a flash of the bios.....
CD DVD ROM doesnt read dvds when i insert the disk
how
long have you been using this CD ROM? I suspect the laser (lens) of the
CD ROM. I think the laser (lens) is weak that's why it cannot read
data/files on DVD.
To confirm if actually its a laser problem,
insert an Audio CD into the CD ROM and see if will play. If it plays,
then obviously, your laser (lens) is weak. But if it doesn't play Audio
CD, then it might still be the laser (lens) or a mechanism problem.
Get
a lens cleaner, use it to clean the lens. If that doesn't solve the
problem, get a screw driver, open the CD ROM cover so that you can gain
access to the lens, use a cotton board to clean the surface of the lens.
This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new CD ROM.
Good luck...........
I have a toshiba satellite a215-s7422. I already
Sounds like a bad hard drive to me - if you're gonna toss the thing, toss it in my direction, why don't you?
"sometimes the drive shows up in bios" is the dead giveaway. the HDD is intermittent.
This thing uses a 2.5", 9.5mm height SATA hard drive, which is pretty darn cheap. You can buy it in stores, eBay, online...
80 gb toshiba laptop is not detected in the bios.
When you power up the computer press F1 or F2 or "del" key then go to advanced .
Then disable SATA .
If already disable then enable it then save settings then check.
Let me know if you need more assistanse.
Thanks.
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
on Mar 26, 2024
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D.
If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM •
Toshiba...
Answered
on Oct 11, 2023
