20 Most Recent
Toshiba 512MB USB 2.0 High-Speed Flash Drive 512 MB USB Portable (PA1398U1MEMFT) Drive Questions & Answers
I have inadvertantly F disked
Flash drive corrupted. No way back. Dont bither using thw remaining part for anything important as likely to fail too . Buy another one
My toshiba 2G is USB not recognized
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
if this does not fix the problem you might try
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver or
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
don
I cannot use it in
The usb is formatted thru Fat32 and when plug into windows, it could has limited functionality. What you need to do is reformat the usb using NTFS type.
Please let me know if this works for you.
Cant locate USB
check the usb might be corrupted
check it in another system so that u can know the problem.
If the usb is working in another system then check the connection of the wires to the pins of the usb slot
Cruzer 512
Is in your old computer an USB slot to plug your flash drive?
Have you on this the driver for your drive ? This is the firts step to transfear your document to your new computer. If no try an other method as connect the computers in an internal LAN connection.
It depend on whith is your operating system.Tell me what is your operating system on each computer.
External hard drive
Your system can't recognise the device and cant load the correct driver. Try to download the correct driver for your's operating system
Toshiba 2 gb flash drive showing 0 disk space
You can only format these drives in mode FAT16 or FAT32.
Try to format it in FAT32 mode and let Windows choose the default sectors for you. This is the better solution.
As I can see, the operating system recognise your drive that mean the correct driver was loaded.
After a new format whith the correct params if your flash drive shows the same thing 0 disk space 0 disk space used, your drive is DEAD.
It happens if you had unplug your flash drive whithout stoping it by cliking on the icon in the notification window (near the clock), the icon is mini drive whith a green arrow. Allways unplug the USB devices by this because you have the +5 voltage on this connector and if you don't do this an arcking effect happens betwen your device and the connector.
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
on Mar 26, 2024
