20 Most Recent
Nikon Coolpix 4500 Digital Camera Questions & Answers
Memory card in camera says write protected
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Memory card is write protected
Take out the memory card from the camera on the memory card itself u will find a small slide switch just slide that switch to the opposite direction if still it says right protected replace the memory card....Hope the problem resolves good luck.....
I just bought a new
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
I have the Nikon D5000.
Take the memory card out insert it into a card reader and connect to a system. After you have backed up all the data without opening the files on the mem. card right click on the card icon and select format . Choose full format option. This would erase all the files.
Regards.
I can not take pictures
Check that if the side bar of your memory card is at unlock?
if it won't help, format your memory card by your computer
When I turn my camera
Card write protected. Remove card and move small button on side card to "un-lock" position. If card was never formatted, then go to menu (movie menu etc.) and select setup (ikon is usually wrench) and select format card. (All content of the card will be erased)
Have just purchased a Nikon
Hello
The problem is likely to be in SD card
This problem mostly comes with SD cards which have lock switch, your card have no switch at all so using a card reader, format it and put back in camera, hope it works if not it should be in warranty, avail your warranty option and replace it immediately.
Good Luck
hope it helps, if so do rate the solution
What do you do when
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
I can't get the pictures
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Nikon Transfer or any other photo cataloging program.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Cannot get write protection off
Memory card write protected
Hello
OK, if the memory card itself is locked, you might
sometimes get this error code. All you need to do is to take out the
memory card and switch the lever on the left side to the unlock.
If
the error is still displayed after you did the above, you might want to
try the card in another camera.
If
the card works in another camera . the problem is with your card reader
in your camera.
If you open you sd slot and look inside with a
sharp light , you should be able to see on the left side of the slot
there is a little copper or spring steel lever switch. This switch work
as follows:
1. When no card is inserted / no write protection ,
the switch is open and thus the protection is off.
2. When locked
card is inserted , the tab is depressed and tells the camera that the
card is lock.
Contrary to popular belief ,the little tab on the
sd card is not an electronic switch and does not physically influence
the card operation itself. If you put a locked card into a camera
without a sd lock switch , you would still be able to use the card
normally.
It is incredible difficult to fix this switch because
of space limitations in the sd card. Look into the sd slot and if you
can see the switch , use a needle to pull the little tab down toward the
base of the camera by about 2mm or until it works being careful not to
bend it.
If this does not resolve your problem , there might be a
short in the switch circuit and the camera will need to be disassembled
to resolve this error. This should cost no more than $50.
Please
feel free to contact me if you need further information
Kind
regards
Andrea
What does memory card is
