20 Most Recent Toshiba DKT2020SD Phone Questions & Answers
How do I set up and use speed dial on a Toshiba
what system u using??
if DK series go to phone port number "000" (at phone press Intercom #401 to check port), check at every phone with display phone.
- to set speed dial press REDIAL SPEED DIAL standard speed dial   code 60 or 600, follow by 9+destination number, REDIAL to confirm.
- to call press speed dial + code or press * + speed dial code (*60 / *600)
- if CTX/CIX must set at adminsrater phone. #66, speed dial code number (200-999), 9 follow destination number #
- to dial press *200...
10/25/2016 3:33:14 AM • Toshiba... • Answered on Oct 25, 2016
How do I set up speed dial for a Toshiba
what system u using??if DK series go to phone port number "000" (at phone press Intercom #401 to check port), check at every phone with display phone.
10/25/2016 3:32:37 AM • Toshiba... • Answered on Oct 25, 2016
How do you retrieve the last number called to this phone?
If you have a CiX system with Caller-ID, a Caller-ID "review" or "log" key must be assigned on the set. Also, a CID buffer of (x) calls must be assigned in system programming. Once done, to review calls, press the CID Log key, scroll up and down using the NEXT/PREV soft key. This does not work on the older DK systems.
2/22/2016 7:09:18 PM • Toshiba... • Answered on Feb 22, 2016
On a Toshiba DKT3020-SD how do I add a night time message?
Here is the location of the manual for download: http://www.manualslib.com/download/375822/Toshiba-Dkt3010-Sd-Digital-Phone.html
3/4/2015 8:04:11 PM • Toshiba... • Answered on Mar 04, 2015
How do I add a beeping sound or some notification for callers who are placed on hold to know we haven't hanged up.
I don't believe this is possible on your telephone system. The feature normally would be referred to as Music On Hold. The manual makes no reference to this feature. Contact your telephone equipment distributer or installer for possible options. http://www.comtechphones.com/images/products_manual/Toshiba%202000Series.pdf
1/6/2015 5:02:16 AM • Toshiba... • Answered on Jan 06, 2015
We have a phone system Toshiba Strata DK40 with
I know this is old, but to help the next person.... On a DK40, you program from port 000, not ext 205. The DK280 is programmed from ext 205. The other info is correct.
10/8/2014 8:35:50 PM • Toshiba... • Answered on Oct 08, 2014
0answers
Check caller id
Caller ID on the telephone is only supported if the KSU is progammed to pass through this information. If you want to view it on the phone level there is a button that can be programmed on your phone to display like caller ID history.
12/31/2013 4:17:42 AM • Toshiba... • Answered on Dec 31, 2013
IS THIS MODEL STILL AVAILABLE
You can buy the phone for 39 dollars at this site.http://www.keyphonesdirect.com/Toshiba/Phones/DKT2020SD-REF.html?gclid=CI_qm9GJzrQCFQmmPAodpkYA1Q
1/4/2013 6:30:49 AM • Toshiba... • Answered on Jan 04, 2013
Drivers for phone zetel n82y how do i get them esp for usb cable?
zetel type n82y security code no active
2/6/2011 10:19:48 AM • Toshiba... • Answered on Feb 06, 2011
I HAVE A TOSHIBA DK280 DKT2020SD MODEL HOW DO I
This manual also applies to your model..The same basic model numbers may have minor changes,thus a change in model number.This is to make support and manufacturing easier and also helps keep costs down.It should at least look very similar in operation to your model.You do not have to sign up for anything and there is no junk after.Click download,then enter the 5 digit code and press download again.It will open a menu.If you want to save it permananetly click save.It will most likely save to your documents folder.For 1 time use click run.You may want to save this site for future reference also.It is excellent and has a wide variety of electronics.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.I really encourage responses so I can follow up properly as I know where you stand and asking someone else restarts all the explaining because we cannot see other 'Expert's' responses.Good luck,Greg
http://www.retrevo.com/support/Toshiba-DKT3220-SD-Telephones-manual/id/3040ag715/t/2/
1/29/2011 6:35:50 PM • Toshiba... • Answered on Jan 29, 2011
How do I program my
People often like to make backup copies of important documents for future reference. Likewise, you might have important voicemail messages that you need to keep archived. If you leave them on your phone service's voicemail system, they might get automatically deleted after a certain period of time or simply to make room for new incoming messages. You can record a voicemail message to a PC and not have to worry about losing access to it on your phone-service provider's system.
Instructions and things needed to fix up the problem.
  • 2.5mm to 3.5mm cell adapter,3.5mm stereo cable,In-line recorder
    Cell Phone Voicemail
  1. Plug the 2.5mm male plug of a cell adapter into the headset jack of your cell phone.
  2. Plug one end of a 3.5mm cable into the adapter's 3.5mm jack.
  3. Plug the other end of the cable into the microphone jack on your PC.
  4. Landline Phone Voicemail
  5. Plug the in-line recorder's modular phone cord into the wall jack for your telephone.
  6. Plug one end of a telephone cord into your telephone and the other end into the in-line recorder.
  7. Insert the in-line recorder cord's 3.5mm plug into the microphone jack on your PC.
  8. Recording
  9. Call your voicemail service, enter the password and listen to your voicemail messages playing through the speakers of your computer.
  10. Click "Start" and then click "All Programs," "Accessories." Click "Sound Recorder."
  11. Click "Start Recording" to record the audio of the voicemail coming from your phone into your PC.
  12. Click "Stop Recording" when you are finished with your voicemail. The audio will be saved in the Windows Media Audio (WMA) format.
Good luck.
1/20/2011 10:35:46 PM • Toshiba... • Answered on Jan 20, 2011
Our company owns the DKT2020-SD Toshiba phone, but
Hi, You can check the manual here
http://phone.manualsonline.com/ex/thread/view/idThread/343173
http://www.p1bc.com/toshiba/toshiba_dkt_2/DKT2020-SD.htm
Regards,
12/15/2010 6:19:44 PM • Toshiba... • Answered on Dec 15, 2010
How can I reset the time?
Depending on the type of Toshiba phone system, the programming steps may vary slightly but this should get you on the right track.
Changing the time on a Strata DK system must be done from the "main" or primary phone. It is usually extension # 10, or # 200. 1.- With the phone on-hook, dial intercom, #, 652 (depending on the system type, the # may or may not apply) 2.- Enter the correct time using HH/MM/SS, like 07:24:00 3.- Press redial
11/8/2010 7:50:30 PM • Toshiba... • Answered on Nov 08, 2010
I have purchased four toshiba
where do i get the central control unit
9/17/2010 10:59:22 PM • Toshiba... • Answered on Sep 17, 2010
The msg light keeps blinking...no messages
its full and there is incoming message hanging, try and delete the already read messages there,
6/5/2010 11:14:09 AM • Toshiba... • Answered on Jun 05, 2010
Can I use my DKT2020SD on a new Toshiba system?
Yes, as long as the system has a digital card in it, you can use that phone with it.
5/17/2010 4:51:42 PM • Toshiba... • Answered on May 17, 2010
0answers
Toshiba DKT2020SD Phone Logo
68 questions posted
Top Toshiba Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Lands Phones
Most Popular Question
reset time
  • Lands Phones
