20 Most Recent Toshiba SD-V55HT 400W Progressive Scan DVD/VHS Home Theater System, Six Channel Audio/Video Receiver... System Questions & Answers
I have a panasonic multi
Recheck the hook-up fo video if it's component video (3-wire). One is not working or you have a couple of them swapped.
7/18/2011 4:16:09 AM • Toshiba SD-V55HT... • Answered on Jul 18, 2011
How to fix Panasonic SA-HT820V stuck on VCR?
my chage thing is black
10/15/2009 3:14:39 AM • Toshiba SD-V55HT... • Answered on Oct 15, 2009
3answers
Make cd's from cassrtte tapes using a Toshiba 1080P dvd player
it should be pretty standard as with any. But I know some of those DVD recorders can be a pain.\
I would connect the Player of what it is you want recorded into the input or video audio in on the back of the DVD recorder, then switch the recorder to record mode and Press play on the output device ( I.E. Tape Player) So the DVD recorder can recieve the VHS signal and record it onto the DVD recorder. Check the Manual in case there are any special settings you may need to set first.
If you dont have them, Go to there site and download them.
http://www.tacp.toshiba.com/dvr/dvdrecorder.asp
Good Luck
1/5/2009 2:02:02 AM • Toshiba SD-V55HT... • Answered on Jan 05, 2009
Toshiba Dual Media Player. Error code L3 when trying to open DVD drawer.
Question edited for clarity. Question moved from 'Dual Televisions'. 'make model (what it is)', first 3 words in all questions please' Nothing on L3 except for the Toshiba Copier. Try Toshiba Support direct. https://www.google.com/search?q=Toshiba+Dual+Media+Player.+Error+code+L3 ..
4/14/2024 9:40:04 PM • Toshiba Audio... • Answered Yesterday
Toshiba 32LV67U audio receiver code.
:It is possible that your TV is not compatible with the Xbox, or that you may need to enter a specific code. I suggest checking the manual for your TV to try and find the audio receiver code, as well as searching online to see if there are any additional instructions on how to connect it to the Xbox. Additionally, you may want to contact the manufacturer of your TV or Microsoft for further assistance.
1/29/2023 11:19:21 PM • Toshiba Audio... • Answered on Jan 29, 2023
My Right earbud on my Toshiba RZE-BT800E sound great but the right earbud cuts out then comes back on and it is often enought that it drives me crazy. Any suggestions?
try another set if $1 earbuds from the dollar store. have 2 sets so when the wires fails, bingo a fix.
8/20/2022 12:28:06 PM • Toshiba Audio... • Answered on Aug 20, 2022
2answers
I have a Toshiba Laptop
Most laptops do have Microphones built in. I do not know for definate that your laptop does, but you can easily test it to find out.
1. Go to the volume control (double click the speaker icon near the clock on the taskbar), go to recording properties and select microphone as the recording source and set the slider to about 80%.
2. Bring up microsoft sound recorder (its in the start menu somewhere) and click record... when you speak you should see a voice print appear in the sound recorder window.
If you do not see a voiceprint, then you probably dont have a built in microphone, but if you do see a voiceprint as you speak then you do have a microphone built in and you can record into your powerpoint shows to your hearts content.
Hope this helps!
1/7/2022 2:51:58 AM • Toshiba Audio... • Answered on Jan 07, 2022
Connecting my Klipsch screw terminal speakers to modern TV. My new TV only has a Sound Out plug. Is there a method to connect my old speakers to my new TV?
The manual is here https://tvna.compal-toshiba.com/us/wp-content/uploads/sites/2/2016/09/toshiba-43_49_55_65l621u_16-0706_web_v2_en_final_lr.pdf The connection for external speakers like you have is called analog audio output and it is shown with a little set of headphones next to it. The issue is the size of that jack. There are two basic sizes 3.5 mm and 2.5 mm . The manual does not say which one is on your television. If you have a set of headphones you can try that would let you know. Otherwise it is trial and error. What you need to do is get a cable that has that end on it and then make the connection to your speakers. Using the wires on the speakers you need to be able to tell what polarity they are and connect two of them to one of the wires in the cable that you found that fits the jack. These are the ground connection and on the cable the ground is usually a bare wire strand. Then the other two cables that are remaining, connect to each of the wires that are coming out of the connection to the television ( they should be colored) One goes to each for left and the other for right. You may want to solder them and make sure that you tape or insulate them against shorts.
9/8/2018 10:05:55 PM • Toshiba Audio... • Answered on Sep 08, 2018
Toshiba SD-V55HT 400W Progressive Scan DVD/VHS Home Theater System, Six Channel Audio/Video Receiver... System Logo
8 questions posted
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Audio Players & Recorders
Most Popular Question
panasonic multi
  • Audio Players & Recorders
