20 Most Recent
Trendware TEW-432BRP Wireless Router (TEW432BRP) Questions & Answers
Hello. I have a TEW-432BRP
First, check to see if the connection to the TEW-432BRP is not what is dropping signal. If the ethernet line is functioning and you don't lose connection, re-attach the router and try performing a factory default reset on the device. Otherwise, you may want to contact Trendnet support for assistance in determining if the router is faulty. From a hardware standpoint, there are several things on the mainboard of the router that could cause your symptom.
11/29/2017 9:04:07 PM •
Trendware...
Answered
on Nov 29, 2017
Can't find pin number
most routers come with a pin number / pass key printed on the label either on the back or underside. another alternative is your provider may provide a (plastic) card with pass-key and admin login details.
11/30/2013 10:06:07 PM •
Trendware...
Answered
on Nov 30, 2013
The NAT Type on my
NAT STRICT
Step 1 : Connect - Router - Computer ( Wired )
Step 2 : Open Router setup by typing http://192.168.0.1 on the address bar of internet explorer
Step 3 : Click Login
Step 4 : On the Left Click Access
Step 5 : Choose DMZ
Step 6 : Click Enable ... And Assign the IP Address of the Xbox /PS3/Wii in it
Step 7 : Click Apply
Step 8 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 9 : Plug the power cord back to the router and wait till the lights are Solid
Step 10 : turn On the Xbox/PS3/Wii
Step 11 : Test the Connection
Step 12 : If Still the Same ..
Step 13 : On the Left under Access Click Firewall Rules
Step 14 : Disable it and Apply
Step 15 : Do Steps 8 through 9
Step 16 : Test the Connection
let me know if this works
Regards
TOM
11/30/2012 12:50:31 PM •
Trendware...
Answered
on Nov 30, 2012
How do i manually configure my router
Connect the router to a pc using Wlan or Wired lan.Once the Lan connection is established, open your web browser and type 192.168.1.1You may get a login screenThe username may be adminthe password differs depend on the model and maketry password or admin in the password field.Once you logged in you can configure itThe config settings can be availed from your ISP (Ip address, default gateway etc)
2/20/2012 10:32:26 PM •
Trendware...
Answered
on Feb 20, 2012
I dont have installation driver
Router does not require driver to be used, all you have to do is to install the hardware and configure it.
1. You have to know your hardware version, so you can download your materials.
There are 5 version of your
TEW-432BRP. 2. Click the link below, If you already know the version.
Main).
TEW-432BRP D1.2R/D1.3R)
TEW-432BRP D1.OR/D1.1R)
(T
EW-432BRP C1.xR)
TEW-432BRP Bx.x)
TEW-432BRP A1)
3. Download
User Guide and
Easy Go CD Files.
4. User Guide will help you to configure your router from start to end.
If problem persist just post and give a brief explanation on the problem.
Hopefully this helps
Thank you for posting.
7/9/2011 2:57:01 AM •
Trendware...
Answered
on Jul 09, 2011
Forgot password
There is a reset button at the back of router devices, get a paper clip and press and hold the reset button for about 10-15 seconds while its on, wait for the lights to blink and load. that should reset your router even the password. but before doing that try the default password first should be located at a sticker on your router. also you may need to re-setup the router to get internet back
hope that helps and please rate, thanks!
3/24/2011 4:12:14 AM •
Trendware...
Answered
on Mar 24, 2011
Well i had my router all setup n working fine for
1. you will have to contact your ISP
2. you will have to clear the router and use the setup CD and reconfigure the router
the Internet Service Provider probably has changed the IP address.
3.check with the router manufacture via their web site and see if there are and updates for your router.
4. you will need to check your firewall setting in the Windows Security settings.
5. you will need to setup your wireless devices again via the Wireless setup wizard provided in the router wireless settings. These instruction are on the CD that came with the router an or the manufacturers website will provide step by step instructions.
2/8/2011 12:38:07 AM •
Trendware...
Answered
on Feb 08, 2011
When the router is connected to Modem, only the
If you have a exterior modem from a company like at&t or verizon,you don't need a router.The modem will work for your wired connection and to laptops wireless.You just need to change settings on the computer,or call the phone company and they will talk you through it.Take the router back and get your money for it.
1/24/2011 2:39:11 PM •
Trendware...
Answered
on Jan 24, 2011
How do I make this router secure,if I didn't on
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
1/22/2011 11:48:50 AM •
Trendware...
Answered
on Jan 22, 2011
How do i port forward
Step 5 : Choose DMZ
Regards
TOM
12/22/2010 7:41:22 PM •
Trendware...
Answered
on Dec 22, 2010
I'm having a few different problems. The main one
Ok, (I am assuming you run windows here)
In the start menu, open "run" (or hit windows key + R)
in the run box type "cmd" and hit enter
in the black window that pops up type "ipconfig" and hit enter
now providing you are connected to the router, the address listed as "default gateway" is the one you will need to put into the browser to access its configuration.
10/31/2010 12:31:39 AM •
Trendware...
Answered
on Oct 31, 2010
I want to secure my
Are you looking for manual or instructions on how to configure.
Security --> WPA security --> select type of security--> enter keys
--> Mac address / Access filter for advanced config.
10/4/2010 9:49:55 PM •
Trendware...
Answered
on Oct 04, 2010
Same Problem. Port frowarding not working. Very confusing.
Virtual Server Name can be anything specified by you. Protocol if not sure TCP/UDP, it is better to select "*" which means both. Both public and private port has to be camera's port. Like in your case it is 50001. LAN server is the local IP address of the Camera given by your router's DHCP or a Static Private IP address
9/2/2010 2:17:37 PM •
Trendware...
Answered
on Sep 02, 2010
