20 Most Recent
ViewSonic PJ458D DLP Projector Multimedia Projector Questions & Answers
It worked beautifully last night
you might need to turn off your computer .
then connect the data projector
and turn on data projector
then turn on computer
hopefully it detects the data projector is connected and switches windows to duplicate projection
On my P.C. F4 key in windows Switches the display manually to duplicate, alternate screen or pc screen only or projector screen only.
As I am not familiar with Apple this support article below might explain the switching of display outputs available on Apple Mac.
https://support.apple.com/en-au/HT202351
Continuesly searching source but not detect vga
1, the interface of inputs is defective
or
2,adjust the resolution of the computer
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail:
[email protected]
Skype: lampdeng.com
YM:
[email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
My ViewSonic PJ458D problem
This is known as 'cycling' and is common with mercury-vapor bulbs nearing end-of-life. When the bulb first starts, it glows dimly and grows in brillance. As the light grows, the pressure and temperature of the bulb also grows--increasing power demand. After a short while, the demand exceeds the ballast limit and the bulb extenguishes until the temperature (and pressure) drop again. Then, the cycle starts over. Bottom line: you need a new bulb (or, the correct bulb).
My PJ458D projector is connected
This is normally caused by a discrepancy between the computer screen resolution and the projector resolution. It could also be related to the computer screen resolution and the aspect ratio of the projector.
Could you please confirm what cable you're using to connect the computer to projector. Could you also please confirm the computer screen resolution and if the projector is set to Auto Source Select along with its Aspect Ratio.
Fan not working
This suggests the bulb is not correctly fitted.
remove and refit- if required consult manual or bulb packaging to make sure this correctly carried out.
come back
My PJ506D DPL Projector starts and stops after a few seconds
Lamp will not turn on.
It sounds like an internal problem. How long have you owned the projector? How long have you been experiencing this issue? Once I have more information I can assist you further.
Thanks,
Lee
Bulb doesn't light
yip, sounds very familiar
steve, does the pj lamp try to fire up.
does it briefly light up then shut off
these are the typ. symptoms of an expired lamp
