20 Most Recent Maytag MEW6530DDS Stainless Steel Electric Single Oven Questions & Answers
2answers
The buttons on the control panel are not working
for an inexpensive board check out www.appliancepartssolutions.com
you will need the part# or click on chat for assistance.
8/28/2022 9:17:09 AM • Maytag... • Answered on Aug 28, 2022
My maytag model # mew6530dds19 has some of the
solution
10/25/2018 4:53:09 AM • Maytag... • Answered on Oct 25, 2018
3answers
Oven is slow to heat up and will not heat above 250
You may have a bad heater coil in the oven or have lost a leg in the 220 line. Check and reset the breaker 1st then check the voltage in the receptacle. It should be 110 from each leg to ground and 220 across the hot legs.
1/4/2015 2:26:57 AM • Maytag... • Answered on Jan 04, 2015
Front Panel Buttons not responding
The touch control panel is a piece of ****! Call MAYTAG, and get a new one, you should still be under warranty. Make them send you the part direct ( its the WHOLE front top panel ), then call a tech to put it in for $50 bucks. Takes about 10 minutes to do. The panel plugs into the electrical Board behind the panel.
FYI...the Top panel includes the Stainless Panel + the Touch controls! Its all one integrated part. The part that goes bad is the "cable contacts" that latch to electrical panel.
FYI....the Cable is made of "thin clear film " similar to Film you put in a Camera.
4/16/2014 8:24:37 PM • Maytag... • Answered on Apr 16, 2014
0answers
Control panel board
Be the first to answer 12/14/2013 9:20:29 PM • Maytag... • Posted on Dec 14, 2013Be the first to answer
0answers
Control panel board
Be the first to answer 10/14/2013 5:31:48 AM • Maytag... • Posted on Oct 14, 2013Be the first to answer
0answers
3answers
Only some of the keys on the keypad of my oven
Hello, Thank You for using FixYa. I will be helping you today.You didnt have to change the computer you need to replace the control panel. The control panel is the whole front piece which has the touch membrane on it. This is common on these units.
Thank You and please rate my answer if it was helpful..
1/26/2012 2:29:38 PM • Maytag... • Answered on Jan 26, 2012
2answers
The oven wont heat over 105 degrees
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
7/13/2011 7:57:03 PM • Maytag... • Answered on Jul 13, 2011
How do I replace a
Hello, Thank You for using FixYa. I will be helping you today. Pull the oven out a few inches turn the power off. You will see two screws on each side of the control when you pull it out remove them. Then take off the control panel you will see the high limit about mid way back. Thats it..
6/21/2011 1:51:56 AM • Maytag... • Answered on Jun 21, 2011
0answers
2answers
I have a Maytag in wall oven (part# MEW653ODDS).
HI. This will be the actual control board in this case, that will be the culprit. the control board, and touch pad, are integrated. These symptoms are indicating that the key pad membrane is damaged. This will require you to replace the entire control board. Once the control is replaced, these issues will be corrected.
6/10/2011 1:24:29 AM • Maytag... • Answered on Jun 10, 2011
MEW6530DDS keypad not working
Check out www.appliancepartssolutions.com for a good price on your control board.Have the part# available you need or click on their "live chat" feature for help.
11/8/2010 12:31:27 AM • Maytag... • Answered on Nov 08, 2010
How do I get the
Unfortunately your going to have to call a service tech out, unless you have a programming manual.
10/10/2010 10:32:17 PM • Maytag... • Answered on Oct 10, 2010
Hello, I have a problem with the touche pad on the
Go to the cumputer settings on you cumputer an turn it on the tuch pad
12/15/2009 7:53:19 PM • Maytag... • Answered on Dec 15, 2009
Why won't my Maytag electric oven heat past 210 degrees?
Hello could be oven thermostat,when you are sure of the part you need check out www.appliancepartssolutions.com cheep parts!
good luck
11/18/2009 4:41:41 PM • Maytag... • Answered on Nov 18, 2009
When I press the bake and broil button nothing
If you need a cheep part check out www.appliancepartssolutions.com
11/18/2009 4:40:20 PM • Maytag... • Answered on Nov 18, 2009
Maytag MEW6530DDS Stainless Steel Electric Single Oven Logo
28 questions posted
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
View Most Popular
Maytag Ovens
  • Maytag Ovens
Most Popular Question
oven slow heat up will not heat above
  • Ovens
