Xerox CopyCentre C20 Black and White Copier
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with Xerox CopyCentre C20 Black and White Copier?
Troubleshooting and Support
Solved Problems for Xerox CopyCentre C20 Black and White Copier RSS Feed Post a New Problem
Xerox C 20 photocopier 'scanner blocked'...
Unable to determine what this means and how to overcome it
1 Solution
The paper will not feed through
When I start a copy it will not feed the paper through and give me an error message "Paper Jam 0". There is no...
1 Solution
OPEN HEAT ERROR
my copier won't make any more cpoies an error shows that there is a heating problem can you help?
2 Solutions
Xerox XC1020
Hello! I have an xerox 1020 and it has worked great for many years. Just recently, when I turn it on, the scan bar goes...
1 Solution
warm up mode error
this is a constant problem. Xerox c20 stays in warm up mode. I know you have to reseat the board on the back, but this...
1 Solution
xerox xc1020
copier prints out solid black copies need help
2 Solutions
blank copies down the centre of the page
i have a copy centre c20 and i am getting a blank copy down the center of the page this error only occurs when the...
1 Solution
Unsolved Support Problems
Unsolved Problems for Xerox CopyCentre C20 Black and White Copier RSS Feed Post a New Problem
scaner bloqueado
La maquina tranco con un papel se removio pero ahora sale codigo scaner bloquedo
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Copier ColorBlack and White
Max. Black Cpm22
Copy Ratio25% - 400%
Best Resolution600 dpi
ENERGY STARWith Energy Star
Copier Specification
Max Media SizeUp to 8.5 x 14 in.
Max Sheet Capacity650
Auto Document FeederOptional Auto Doc. Feeder
Media TypesTransparencies, Labels, Envelopes
General Info
Monthly Duty Cycle20000 pages
Duplex PrintingWith Duplex Printing
Dimensions
Depth17.4 in.
Height19.2 in.
Width21.3 in.
Weight58 lb.
Xerox Contact Information
Main support number1-800-821-2797
Sponsored Links
Loading problems.
Top Copier Experts
tryit
18 solutions
Office Machines, Small Appliances
Ask Me
Guru
trickieo
5 solutions
Office Machines, Computer Accessories...
Ask Me
Guru
pomtek
4 solutions
Copiers
Ask Me
Guru
Repair Service
