20 Most Recent
Aiwa CDC-X207 CD Player Questions & Answers
ER03 code pops up every
ER03 Focus Error .Check that the CD is loaded properly(right side up) and the CD contains proper data.Try pressing the reset button.When you press this button use the tip of a pointed object such as pencil or toothpick.
Aiwa cdc-x204
try disconnecting the battery to see if that will reset the device. Let me know what the outcome is and we will go from there to fix this. Just make sure to respond here in a timely matter so that we can get you on your way as soon as possible.
good luck
Fuse for the ash tray for the crysler 300
Fuse #9 feeds the power outlet and fuse #18 feeds the lighter outlet (this is the one I believe your having trouble with).
They are both located in the fuse box in the trunk, next to the battery. If you open the trunk and lift the floor up you'll see them hiding under there. The numbers should be called out on the cover for the fuse box.
