20 Most Recent
Coby TF-DVD7333 Portable DVD Player Questions & Answers
No picture and no sound on dvd7333
HelloThe backlight inverter board of your TFT is faulty. Soemtimes the CCFL tubes have the trouble. Anyway, there is no backlight coming up. Check for it. OK.
DVD player gives me the sound but the screen is
There is a inverter next to the screen under the plastics either below the screen or next to it. This sounds like a bad transformer witch is located on the inverter board. They can be ordered on line or through most laptop stores. They are not hard to change but a common problem. make sure you know what you are doing before you attemp this. Thanks
Not reading disk
dirty lenses on the drive can cause this, no signal comes back to the laser, so it thinks there is no disk
especially with kid fingers and a flip open case,
iso-propyl alcohol on a swab removes fingerprints, jelly, cake, and all sorts of stuff from a lens, vaccuum cleaners are good if its just dust
Where can i get the battery 7100 coby TF in fresno and do they have one ?
Have you already removed the battery? There will be information on it telling you which battery to use as a replacement. As a general rule I would suggest you Don't start taking things apart if you are not sure what you are doing! You could cause more problems than you're trying to fix. Ask at your local TV repair shops and even some of the computer repairers. They may be able to help you. You would have to ask them directly if they have one in stock but commonly if it isn't a commonly used battery they will have to order one in for you.
If you have the battery details you might be able to get one online.
HOW DO I PROGRAM MY COBY UNIVERSAL REMOTE CRC-02
If you don't have the code for your device, you can use the auto search method to find the correct code. Here are the steps:
Turn on the device you want to program.
Press and hold the Setup button on your remote until the LED light turns on.
Press the device button (TV, DVD, CBL, etc.) for the device you want to program.
Press the CH+ or CH- button repeatedly until the device turns off.
Press the Power button to turn the device back on. If it turns on, the remote is programmed successfully.
Otherwise, you need to search for the manual for the remote.
Coby RC-028 under-the-counter television. on local channel 5 the audio is both English and Spanish. How do I turn off the Spanish portion?
If you are hearing both English and Spanish audio on local channel 5 on your Coby RC-028 under-the-counter television, you may need to adjust the language settings. Here are some steps you can try:
- Press the "Menu" button on the remote control.
- Use the arrow buttons to navigate to the "Audio" or "Language" menu.
- Look for an option called "Secondary Audio" or "SAP" (Secondary Audio Program). This option controls the language of the audio.
- If the "SAP" option is set to "Spanish," select the option to change it to "English" or "Off" (depending on your preferences).
- If there is no "SAP" option, look for a language setting or a similar option that may control the audio language.
- Save the changes and exit the menu.
- Test the TV to see if the language has been changed.
If these steps do not resolve the issue, consult the user manual for your Coby RC-028 or contact the manufacturer's customer support for further assistance.
