20 Most Recent
Fuji FinePix A600 Digital Camera Questions & Answers
I have a Fujifilm Finepix
You may have improver card fitted. Please remove and re fit the card. If problem persist , please try another good / new card. If you have no problem with new card, your existing/previous card is broken.
Regards,
Fuji FinePix S3400 digital camera - battery issue
Well first of all may i start by saying merry Christmas Michael, i presume that is your name, you seem like a Michael, how are the family? Who's cooking dinner this year? How's the job? and them footballers eh, what's there story eh? Go the footballers!! Anyway old pal, old friend, good buddy Mad Mike, Ooh err Mad Mike, theres only one Mad Mike!! Go on you nutter! Anyway, the problem, old mateypoo's is the battery, i know, the battery, who'd have guessed? Not me thats for sure, THE BATTERIES, get out!! Yes its true, normal batteries are dogshit in any digital camera, you need to buy Lithium Batteries, they're a bit more expensive but you'll get 6 to 7 hundred shots out of them babies. woooooooooooooooohhh!!!!!!! YEAH, take care sausage, merry xmas
When I try to turn on my FinePix A600 is beeps, the lens comes out, the light on the back flashes yellow, then it flashes red, the lens goes back in and the camera turns off. I bought a second FinePi
I'm curious....the camera came out in 2006....how did you buy a second one?...and more importantly, why? If something doesn't work, the first thing people do isn't to go out and buy another one. Anyway, from your description, the problem seems to lie with the cards, not the camera. All memory cards must be formatted (sometimes called "initialized") in the camera before use and regularly after downloading the pics to the computer. This erases the card and brings it back to original condition so download any pics you want to save using a separate cardreader if necessary and then, format/initialize them in the camera.Also, how old are these cards?....they don't last forever.
How do i get longer
Most camera does have a specific SD card for it. I recommend to read the manual before putting a SD card not all camera can read memory card and buy the type and correct value of SD card some camera can take only 1 GB some 2GB or higher but some may only accept 512MB or lower. The higher the memory the the longer the capability of storing long videos but it all depend on the capability of your camera. Thanks hope this helps.....
How do I download the
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Write error problem
Welcome to Fixya. "Write error" problem occurs when the data could not be recorded due to an error connection between the memory card and the camera. Also this error appears when the image that your trying to save is too large to fit in the available space in your memory card.You can try this steps to get rid of this error.
1. Turn off the camera.
2. Take off the memory card ad try to clean it with soft and dry cloth.
3. Re-insert memory card.
4. Turn on the camera again.
If you still have the same error, try to replace your memory card with a new one.
If the error still persist, you need to contact your Fujifilm service center.
Please let me know if you have any questions.
Thank you for using Fixya,
seancarlisle
Ineed to load my camera on myPC running windows7
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Focus Error when I turn on the Finepix A600
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
My camera keeps flashing zoom error and i cant go
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
found this helpful.
Regards
Andrea
'zoom error'
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
center for a evaluation to see if it would cost more to repair than to
replace the camera.
Hope
found this helpful.
Regards
Andrea
I have just boughta camera,
I'd guess it's using the built-in memory ONLY, and ignoring your memory card... Make sure the card you're using is fully supported by your camera model and that it's not on Locked mode!
Zoom error.....don't know what to do help!!!!!!!!!!!
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
found this helpful.
Regards
Andrea
When i turn on camera zoom error flashes and lense
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
found this helpful.
Regards
Andrea
Zoom error abd the lense
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
found this helpful.
Regards
Andrea
Zoom error
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
I have a zoom error
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
Regards
Andrea
My fuji fine pix a600 has a zoom error
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
Regards
Andrea
