20 Most Recent Fuji FinePix F460 Digital Camera Questions & Answers
Forgot to set time and
Hello and Welcome to FixYa!
If you have forgotten to set date and time then you can also set date and time after turned on the camera. to set date and time follow the given instructions:
  • Press the Menu button on the rear of the device, then choose Set with left or right button, Then go to Setup menu.
  • Select Option followed by time icon. This brings up the date display. The display blinks as it has not yet been set.
  • With the help of Right or left buttons select Year, Month, Day,Hour or Minute. Then press Menu/Ok button after the settings completed. Now every picture captured with the Fujifilm FinePix F460 will save the date and time to the pictures
I hope this solution helps you
For further assistance, I am here to help.
Thanks and Keep Visiting FixYa
6/21/2015 10:08:08 PM • Fuji FinePix... • Answered on Jun 21, 2015
Import photos from Fuji 460 to computer
Transferring digital photos from your camera is necessary to clear your memory card. Adobe Photoshop Elements makes downloading photographs easy, or you can import pictures to your computer with Windows. Then you can make prints, copy photos to a CD or DVD, and share them online.
3/7/2015 11:21:00 AM • Fuji FinePix... • Answered on Mar 07, 2015
0answers
Cannot get memory card into camera
F460 uses Xd picture card format. Obsruction to the "Insert/eject" mechanism is probable cause. Card inserted incorrectly? Removed incorrectly? Replace card slot. Probably not cost effective though.
1/21/2014 10:12:23 AM • Fuji FinePix... • Answered on Jan 21, 2014
I cannot get memory card into camera
Your camera uses "xD-Picture Card" memory cards. To insert the memory card, you have to open the battery cover and you see a little room, where the card goes in. There should be a gold marking indicating where the contact area on the card should be when inserted. Don't try to insert any other kind of card. I saw a xD-Picture Card adapter, where you could insert a micro SD card, but I'm not sure your camera can work with such a adapter.
1/20/2014 4:01:56 PM • Fuji FinePix... • Answered on Jan 20, 2014
Battery wont charge
As in the first part of the manual is explained, when you have inserted the battery correct and you then plug in the charger, the charger light should go on. When the light is out, the battery is charged. When the light blinks, your battery is fault. When the light does not go on, when you plug it in a power outlet, the battery is not inserted correct, or the contacts are dirty. If you want to clean the contacts, please only use a dry cloth. Never us a sharp tool. It would damage the contacts bend repair. Even when you plug in the charger, with a fully loaded battery, the light should go on for only a few moments. Make sure the power outlet works normally. and the power cable is not defect.
1/8/2014 1:45:13 PM • Fuji FinePix... • Answered on Jan 08, 2014
0answers
2answers
My f460 says zoom error
Here are some troubleshooting steps for Fuji "zoom errors".
12/10/2012 2:15:24 AM • Fuji FinePix... • Answered on Dec 10, 2012
2answers
Menu button and Zoom buttons not working
Yes im having the same problem ,however i open/disassembled my camera and my results was a broken ribbon connector from the Rear Button Board to the Main circuit board.....
The only problem is i can not find any parts list information or where i can get this part....
can any one help me with this??
FUJIFILM F460 Camera
REAR BUTTON CIRCUIT BOARD
Rear Button Assembly
Thanks
Wooker
NOKTURNAL CAR CLUB
BALDWIN PARK, CALIFORNIA
12/9/2012 6:43:32 PM • Fuji FinePix... • Answered on Dec 09, 2012
When i take a picture
Is it purple or green stripes? If so it is your ccd sensor which will be fixed free by Canon in warranty or not.
11/1/2011 5:22:20 AM • Fuji FinePix... • Answered on Nov 01, 2011
When I turn on my camera, it shows a black screen,
Is the lens protector opening in the front of the lens???
If it is and things are still black then throw it out... it will cost more then it is worth to fix...
Lens Errorfix for Digital Camera
heatman101
5/26/2011 1:45:02 AM • Fuji FinePix... • Answered on May 26, 2011
When I try to take
Since there is less light, the camera leaves the shutter open for a longer time....plenty of time for you to move the camera slightly enough to blur the pictures. Here are some suggestions: 1. If the camera has some version of "shake control" or "image stabilization", turn it on. 2. Set the ISO to a higher number. 3. Turn on more lights inside if possible. 4. Use a tripod or set the camera on a firm surface.
4/25/2011 4:27:12 AM • Fuji FinePix... • Answered on Apr 25, 2011
Shutter does not close fully..
If the shutter isn't closing it could be annoying or expensive. The dust may be enough to jam the little motor or mechanism that close and opens the shutter. If you are lucky all that needs to be done is to clean out the track with a qtip(cotton swab) or a very small brush or both. If the mechanism is damaged or the cleaning does not help them the repair cost will be more than a new camera. Unfortunately repair parts for cameras are very expensive. If you have a camera shop they should be able to look at it and tell you if a cleaning will help or what your other options are.
1/20/2011 5:16:27 AM • Fuji FinePix... • Answered on Jan 20, 2011
2answers
I am having problems loading
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
1/19/2011 3:52:50 AM • Fuji FinePix... • Answered on Jan 19, 2011
Fuji FinePix F460 Digital Camera Logo
86 questions posted
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
forgot set time
  • Cameras
