20 Most Recent Rosen inVUE II Video Ent. Sys '00-'02 Chevy Suburban w/o Sunroof Questions & Answers
2answers
Problem
1. Check fuses
2. Check Cables
3. Check mechanical Damage to units including swtiches.
4/15/2015 9:47:09 PM • Rosen inVUE II... • Answered on Apr 15, 2015
1989 suburban k2500
head gasket no doubt about it
9/27/2009 3:11:30 AM • Rosen inVUE II... • Answered on Sep 27, 2009
2000 suburban sunroof wont close
My sunroof did not close all the way, but would work back and forth. I postitioned the sunroof half way, disconnected the battery for 1 min then tried it again. The system that keeps track of where the sunroof was positioned got reset and it now works great.
7/26/2009 10:14:53 PM • Rosen inVUE II... • Answered on Jul 26, 2009
Rosen inVUE II LCD has blinking power light but no display -
Check the fuses first - there will most likely be one that is hot in accessory and one constant hot.
1/17/2009 12:39:59 PM • Rosen inVUE II... • Answered on Jan 17, 2009
Invue system for an 02 suburban.
First you can download a manual for your model from Rosen's site. It explains all the on screen programing you can do. You'll need a fundtioning remote to do this I think. You can get one from a local Rosen dealer for about $35 (see deaker finder on Rosen's site. Yes your sound does come through the radio on 88.7 or 88.9FM througha modulator installed inside your dash. Otherwise you use infrared wireless earphones (Wal-Mart sells them). The "Speaker" button on the passenger side of the LCD screeen turns the car speakers on or offf.
1/17/2009 12:13:14 PM • Rosen inVUE II... • Answered on Jan 17, 2009
Car won't start
your neutral switch is in your gear shift. it's just a little button on the shifter if it's an automatic... and if standard it''ll engange when you push the clutch in... your ignition switch might be fried if you are turning the key and the wire is getting no power..
3/12/2008 4:43:20 PM • Rosen inVUE II... • Answered on Mar 12, 2008
'02 monte carlo ss problems
if you give gaz its shake if you let go the gaz does it still shake if it still skake it probably wheel balance if it shake in the stering its the front if you feel it in our seat its the back but if it vibrate only when you give gaz it could be a cv joint or universel joint cheers
1/28/2008 11:36:29 PM • Rosen inVUE II... • Answered on Jan 28, 2008
How do I order replacement accessories (remote, headphones, game controller) for the Rosen XR1020 overhead dvd system?
A few options: You can contact the manufacturer, VOXX Electronics, by phone at 1-800-645-4994 or by email at [email protected]. They may be able to provide you with the accessories you need or direct you to an authorized dealer. You can visit the VOXX Electronics website and look for the XR1020U model, which is the same as the XR1020 but with a universal trim ring. You can find the list of accessories and their part numbers on the product page. You can then order them online or call the customer service number above. You can search for the accessories on online marketplaces such as eBay, where you may find new or used items for sale by other users. However, you should be careful to check the seller's ratings, reviews, and return policy before making a purchase.
2/26/2024 2:45:09 AM • Rosen Car Audio... • Answered on Feb 26, 2024
I need a wiring guide for a Rosen av7500
what is your budget?
2/2/2022 4:03:54 AM • Rosen Car Audio... • Answered on Feb 02, 2022
0answers
Rosen roof dvd player has sound but no picture please help
Hi Gill. Check, Make sure the cables are connected. Try cleaning the laser and the DVD. Make sure the TV is on the correct input. try swapping one of the sound cables to see if the yellow cables is in fact damaged. 1) Plug the DVD player in to the TV that it does work on. Make sure there is no disc in the player. Check the DVD players set up menu. Look in the Picture menu and change the output to "RGB" Move the player back to the TV/VHS Combi. Select the input that gives you RGB1. 2) Same as above, but this time change the Picture menu to PAL (or composite or Video....whatever is the other option name that isn't RGB or S-Video). Retest on the Combi, but this time you want AV1. If these don't work then you might need to have a look in the TV manual about connecting external sources. It could be that because the combi has a recorder that it's trying to stop you from copying DVD to VHS. See if there's an input on the combi that bypases the recorder. Read more: https://www.diynot.com/diy/threads/dvd-problem-sound-but-no-picture.211588/#ixzz5FYrJiX6o I found all this on the internet so not sure if it will help you out. or try this link. dvd player has sound but no picture Google Search
5/15/2018 9:32:31 AM • Rosen Car Audio... • Answered on May 15, 2018
Over head Rosen DVD player won't eject
Please post once
5/3/2018 8:40:32 PM • Rosen Car Audio... • Answered on May 03, 2018
Rosen overhead DVD player won't eject
It is cheaper to replace it than try and find someone who can fix it.
5/3/2018 8:40:19 PM • Rosen Car Audio... • Answered on May 03, 2018
Car Audio & Video Logo
12 questions posted
Top Rosen Car Audio & Video Experts
ZJ Limited
ZJ Limited
Jerry Naidoo
NOEL
NOEL
Are you a Rosen Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Rosen Car Audio & Video
Most Popular Question
  • Car Audio & Video
