20 Most Recent Harley Davidson KNG America 026711 Harley-Davidson Fat Boy Replica Phone Questions & Answers
KNG America Harley Davidson Motorcycle Lamp Repair.
Big tip 'o' the hat to harleyds96 for giving me the impetus to get after it and tear the lamp down and sort it out. You'll need a precision Phillips #1 screw driver to remove the 8 screws. You'll have to pry the 4 little rubber pads off that double as screw hiders
Once you've carefully separated the bottom plate from the rest of the pedestal, you'll see that you need an extra set of hands to hold the plate, amber glow ring, and the main lamp body with, while you fight with the little fuse box in the center of the lamp.
They all have to be held, because the speaker wire runs through the amber ring to the bottom pad, and can't be unplugged, 'cuz it's soldered. No spade connectors, nah, that'd be too easy - and complicated. They'd like to make it so much easier to toss out another $80 for a replacement, 'cuz you stupidly lost the receipt!
So now that you've got everything separated, you discover that there's another two screws holding the ends of the fuse box to the main body of the lamp. Yes, they must be taken out too, so's you can properly fight with the four little clasps holding the fuse box together!
If you can get it popped open without ripping wires from their solder connection, you're a neurosurgeon! I lucked out, 'cuz I did the operation whilst sitting at the computer desk, so the bottom two pieces could rest on it, without ripping the speaker wires off of the speaker, while at the same time, the main body of the lamp was resting in my lap.
Now that you've succeeded in getting the box open, you'll see that you have that little fuse there, that the Harley lady mentioned above found. It's stamped - 1A/250 V, which, I suppose, would mean it could be plugged in down undah, where they use 240 volts.
So I'm going to see if I can find a 2A/250V fuse somewhere, and if that's too hot for it - TOUGH! I'll have a Harley Davidson plastic patty melt! vonster.vaughn
3/28/2016 6:15:28 PM • Harley Davidson... • Answered on Mar 28, 2016
Issue with Harley regarding cam bearing - 2000 Road King Classic
our bike is out of warranty by 8 years.....should i ask for warranty on my 1987 FXR? or should i just man up!
5/23/2010 2:17:48 AM • Harley Davidson... • Answered on May 23, 2010
1998 dyna wide glide
check fuel level and petcock.getting fuel? next check for spark ground spark to cylinder fins and crank motor, no spark check cam postion sensor for voltage while cranking (if fuel injected check crank positoin sensor for voltage) if you get voltage replace coil
1/8/2010 8:30:18 PM • Harley Davidson... • Answered on Jan 08, 2010
2000 road king
use a good brand of synthetic 20-50 in everything the primary fluid will last around 10,000mi the tranny fluid the same and the engine around 6000mi the tranny takes 3/4qt the pri takes 7/8qt and the engine gets 2 3/4qt check the levels with bike upright check engine oil level after warm up top off as needed
1/8/2009 1:18:07 AM • Harley Davidson... • Answered on Jan 08, 2009
Wharfedale touch dect triple phone with answerphone
Hi Michell,
I have the same unit and mine bleeps when I have new messages.
anthea
7/14/2008 8:18:40 PM • Harley Davidson... • Answered on Jul 14, 2008
2answers
I have just bought the
Where can I find a manual for Bellsouth 4300GR phone? Please help!
6/21/2008 4:29:58 PM • Harley Davidson... • Answered on Jun 21, 2008
New harely
Take it easy and keep the revs low - don't thrash the arse off it to start with. Easy gear changes and use the clutch well. Change the oils at first 1000 miles. If it is brand new then the dealer should be giving you your first service free under warranty?
5/23/2008 11:30:53 AM • Harley Davidson... • Answered on May 23, 2008
Whining sound just started
I do not know where it stared from or when
11/26/2014 6:58:30 AM • Harley Davidson... • Answered on Nov 26, 2014
Whining sound driving
I would need some more description of the sound and like where it is coming from.
11/26/2014 6:57:50 AM • Harley Davidson... • Answered on Nov 26, 2014
Trouble code p1655
online
5/26/2014 5:26:17 AM • Harley Davidson... • Answered on May 26, 2014
FXR 5 speed transmission wont shift 1st gear just spins like neutral?
Did you make sure the shift fork is on proper direction.Soetimes the're offset.These things happen.
4/14/2014 11:56:11 PM • Harley Davidson... • Answered on Apr 14, 2014
0answers
2008 ultra glide how does oil get into the air
normal crankcase venting is done through the heads and vents into the carb to be burned but you will see oil on your air filter, normal,just ride it
12/31/2009 6:37:02 PM • Harley Davidson... • Answered on Dec 31, 2009
I need a manual for a speakerphone 210 with a 13 memory an lcd
google speakerphone 210 manual for choices.
4/5/2024 12:49:29 AM • Lands Phones • Answered on Apr 05, 2024
How can I set up favourites on Eircom landline please?
Question edited for clarity. Question moved from Video Consoles category. Trying to find a manual. Are you sure that model is correct? Eircom should give you a manual PDF. https://www.google.com/search?q=Eircom+perform+100+manual and https://www.google.com/search?q=Eircom+perform+100 ..
3/26/2024 3:10:48 AM • Lands Phones • Answered on Mar 26, 2024
Harley Davidson KNG America 026711 Harley-Davidson Fat Boy Replica Phone Logo
15 questions posted
Top Harley Davidson Lands Phones Experts
k24674
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Harley Davidson Lands Phones
Most Popular Question
kng america harley davidson motorcycle
  • Lands Phones
