20 Most Recent Hitachi Travelstar 5K100 HTS541060G9SA00 60GB 5400rpm 150MBps Serial ATA Serial ATA/150 I... (0A26923FT) Hard Drive Questions & Answers
2answers
What is the password for hitachi HTS545025B9A hard drive
The password is your responsibility. If you forgot that's a bad mistake, or if it's belongs to someone else ask them.
10/24/2021 3:27:12 PM • Hitachi... • Answered on Oct 24, 2021
0answers
0answers
Partition
Be the first to answer 9/22/2012 4:17:51 AM • Hitachi... • Posted on Sep 22, 2012Be the first to answer
Sata drivers for win xp
If you use a XP SP3 install CD it should include the sata driver.
9/14/2012 6:58:47 PM • Hitachi... • Answered on Sep 14, 2012
How to get master password for hitachi hard drive
Wow, why don't you know the password? I'm not calling you a thief, but 99% of the time when you encounter a computer that has a lock on the hard drive and the person in possession of the computer does not know the password, the computer is stolen. The original owner puts a lock on it to keep thieves from getting to sensitive data.
6/3/2012 4:56:11 AM • Hitachi... • Answered on Jun 03, 2012
I have a HITACHI TRAVELSTAR
If they can recover data, they will can repair too taht hdd, if they not know how, say them with Live CD Hiren's boot, in there 2 program realy working for rapairing, MHDD, and in Hdd tools\ TEST AND REPAIR HDD
6/3/2011 7:32:44 PM • Hitachi... • Answered on Jun 03, 2011
I have hdd HTS541060G9SA00 on label of this write
Yes, it's a SATA. If you have a PATA connector on it then you bought a fake or a piece of junk.
3/5/2011 10:44:47 PM • Hitachi... • Answered on Mar 05, 2011
My computer has no problem
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
12/13/2010 4:09:35 AM • Hitachi... • Answered on Dec 13, 2010
Seems to power up ok but bios does not see it. no
make sure sata/scsi is enabled in bios usually by pressing f2 some boards come from factory to read ide and sata diabled make sure it is enabled
11/3/2010 3:10:37 AM • Hitachi... • Answered on Nov 03, 2010
How to download the driver
I am not familiar with Linux but have you checked your Bios to see if Sata Hard Drive is recognized in there??? Most of the time you have to set the bios to recognize a Sata drive because 90% of Hard Drives are still IDE and most bios software is still recognizing the IDE drives. I know I had to reset everything on my Motherboard and Bios when I changed over from an IDE to SATA Hard Drive.
11/1/2010 3:47:16 PM • Hitachi... • Answered on Nov 01, 2010
When I connect USB it system detects the hard drive but could not
Try it on another computer and see if you can open it up there. If it's still showing as 0 bytes then it's obviously a problem with the usb drive.
If it's a thumb drive (or some other solid state storage) then you're probably going to have to look into a data recovery service as they're going to have to remove the memory chips to access the information.
If it's an external case with a hard drive inside it then the best bet would be to open up the case and pull the drive out. Try connecting the drive to a computer (make sure the computer is off, then turn on) that way or through another external case. Be careful though, if the drive is making any funny noises or clicks then you could be damaging it and you'll need to again, take it somewhere for data recovery, also if the drive is not spinning at all (it's easy to tell) then you'll have to take it in. There's a chance it'll work fine though and your external might just be bad
3/2/2010 7:54:11 PM • Hitachi... • Answered on Mar 02, 2010
Poweron laptop hdd not found
there is a problem on hardware get it to be checked
11/24/2009 3:28:45 PM • Hitachi... • Answered on Nov 24, 2009
Dell Inspiron E1505 won't boot
Try this site to look for hard drives. Not just any drive will work, so make sure you confirm with the company's sales or tech support to make sure it'll work.
LINK
12/11/2008 5:45:10 PM • Hitachi... • Answered on Dec 11, 2008
500 GB External Hard Drive Hitachi
Operating System? Computer specs?
I'm afraid we need some info before we can help.
3/17/2008 9:51:28 PM • Hitachi... • Answered on Mar 17, 2008
My burner is not working
This sounds to me like your CD/DVD is borked,& you need a new one, sorry.. Ya see, really the only way ya can "see" if it is OK, or not, is to try another one... to isolate the problem. They break down quite commonly I have found. If you are unable to do this, then it's off to the repair shop.. As I always say in these cases get a firm "Quote" and an explanation of repair.
9/1/2007 7:50:35 AM • Hitachi... • Answered on Sep 01, 2007
3answers
Transfer data and operating system from one hard drive to another
Use AOMEI Partition Assistant,a free Windows partition software, to clone data or OS from one hard drive to another. http://www.disk-partition.com/copy-disk-partition-wizard.html
8/18/2017 9:10:08 AM • Hitachi... • Answered on Aug 18, 2017
Computers & Internet Logo
24 questions posted
Top Hitachi Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
TravelStar Hitachi
  • TravelStar Hitachi
Most Popular Question
hitachi travelstar
  • Computers & Internet
