20 Most Recent Hitachi 46F510 46" Projection HDTV Questions & Answers
Hitachi 46F510 46 in. HDTV Television will not power off
Signals from the remote control is either not correct, or the remote control is damaged. Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. https://youtu.be/wUpnETSm6_k https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean] https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
6/4/2017 10:27:21 AM • Hitachi 46F510... • Answered on Jun 04, 2017
0answers
0answers
HITACHI 46F510 ALL CHANNELS SNOW LIKE DOTS
if its clear on dvd your antenna is not good or properly installed
7/19/2013 9:47:03 PM • Hitachi 46F510... • Answered on Jul 19, 2013
I have a panasonic pt-61hx42 tv and the picture is dark and hard to see night sceens Is there another bulb besides the three colored bulbs
have you already check in the menu adjustment with the brightness,how about cleaning of the reflector inside doesn't work?
9/28/2012 5:53:21 AM • Hitachi 46F510... • Answered on Sep 28, 2012
Screen turn to red hue and then back to normal
Not uncommon on this model as a lot issues with the red and most of them are caused by touchy master screen controls. The set has a black rectangular block with three screen and three focus controls, for whatever reasons the red screen control always seems to be the flaky one and usually a very tiny adjustment of that one does cure the problem.
8/28/2012 12:47:06 PM • Hitachi 46F510... • Answered on Aug 28, 2012
What causes my picture to go pink all of the sudden ?
Examine the screen with set on and color set to zero--stand back and look= is screen pink to red color?If so it may be a common issue on this Hitachi. Usually it is an adjustment inside the set of the red screen control needing to be turned just slightly down---these are known for the red control "drifting" just slightly from time to time--answer is based on model number indicated here.
5/31/2012 7:03:09 PM • Hitachi 46F510... • Answered on May 31, 2012
I have a HIT 51F500 HDTV PROJE, I cannot find a focus block Anywhere
The block rarely if ever goes bad---what is the issue?
5/17/2012 11:18:18 AM • Hitachi 46F510... • Answered on May 17, 2012
The colors are out of alignment.
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
5/12/2011 11:05:51 PM • Hitachi 46F510... • Answered on May 12, 2011
Blue shading border 50in rear
As question shows it is Hitachi 46F510 rear projection tv and blue shade border problem is related to convergence output section. Please try to adjust convergence as option would be available in tv Menu and if that does not help then it is hardware problem like convergence output chips going bad or dry/ cold solder joint developed in that circuit area etc.
This is job of tv technician to do solder work in convergence output section of tv to solve the blue border issue in picture.
Hope these info will help, let me know if there is additional question.
Thanks.
4/11/2011 11:36:58 AM • Hitachi 46F510... • Answered on Apr 11, 2011
Hi, My Hitachi 46F510 rear projectiont
my whole sceen has turned green,can't even make oput the picture!
3/19/2011 7:54:29 PM • Hitachi 46F510... • Answered on Mar 19, 2011
The overall picture is much darker. Night scenes
The brightness settings must have been changed somehow. Just go into your tv menu (there should be a menu button on your remote). Navigate to Picture Settings (this maybe different but there should be something similar) and move the brightness slider up but not too much or the picture will begin to look "washed out". Hope that helps.
3/2/2011 7:03:52 PM • Hitachi 46F510... • Answered on Mar 02, 2011
My tv just went out no sound no picture
Hi. Maybe you have a bad Horizontal Out. Need replace 2SK2771 and a fuse E907.
2/18/2011 3:35:25 PM • Hitachi 46F510... • Answered on Feb 18, 2011
My hitachi 46f510 is stuck
Have a nice day.
2/18/2011 3:33:38 PM • Hitachi 46F510... • Answered on Feb 18, 2011
Hitachi 46F510 46" Projection HDTV Logo
82 questions posted
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
hit 51f500 hdtv proje cannot find focus
  • Televison & Video
