20 Most Recent
Rosen CV7080D Portable DVD Player Questions & Answers
Two dvd's stuck in player thanks to a busy toddler
I had the same problem... my DVD took one in even though it already had one in there... Tweezers did not work until we used a pie server covered in masking tape with the DVD attempting to eject and then grabbed one DVD out. The DVD player works too!
Rosen CV6880D scheme
I have a big problem, I recently bought a van DODGE GRAND CARAVAN 2002 model, in this coming Rosten CV6880D player installed, but I want to play DVDs or CDs including the speaker not working. please help.you show me one tutorial or manual
It looks like it reads
Check the A/V ouput on another monitor and if there is no display then this section is faulty.
If picture is present then the monitor is faulty and needs a check for the backlight circuit or the LCD.
No power to Rosen DVD
Hello and Good day to you.
Please Follow this procedure for trouble shooting.
- Remove the cover of your DVD player by Loosening all screws.
- Check the input voltage of the power supply 220v/120v AC.If don't have input supply that comes from the ac cord,replace it.
- If you have a input voltage supply comes from the power
cord.Check the output voltage of the power supply such as 5vdc and
12vdc.
- If you don't have output voltage from the power
supply.Check the fuse if busted,check open/change value of
capacitor,check power transistor (regulator) if shorted and leak/bulging
top capacitor of the power supply board.If you found any defective parts
replace it.
- If you have output voltage comes from the power supply.The problem could be the main board,replace it.
- If you already done this procedure,test it by power ON the DVD player.
I hope this information will be helpful.Thank you and good luck.
Please do not forget to testify and rate me if this solution helps you..
No picture appearing
check first all connections. if this not solve the issue, this could be a problem on the lcd or in the video cable
Cant get the module
Hi, The A7 has 3 sound modes. With the unit on press the speaker button and on the screen it will say either "Headphone sound only" or "Speaker sound enabled". Pressing the speaker button will toggle these modes back and forth. If you don't hear any sound when it says "Speaker sound enabled " it may be that it was wired using the FM Modulator, which means it uses the car speakers. For them to work, turn on your radio and tune it to 87.9 or 88.3. Good Luck!
Rosen a9 dvd player
Hi, Rosen plays repairs close to the vest, they want you to take a digital picture and send it for help. I don't know if they will send you any info or not but you can email them at
[email protected] and see. I also have a phone number, don't know how old it is, 909-898-9808. Good Luck!
