20 Most Recent JVC GR-DVX9 Mini DV Digital Camcorder Questions & Answers
There is often a small battery inside the unit or accessed from outside that holds the memory that the device was last set. Yours is defaulting to maximum zoom. And in fact it does.
Built-in Clock's Rechargeable Lithium Battery
To store the date/time in memory, the clock's rechargeable
lithium battery is integrated in the camcorder. While the
camcorder is connected to an AC outlet using the AC
Power Adapter/Charger, or while the battery pack attached
to the camcorder continues to supply power, the clock's
rechargeable lithium battery is always charged. However,
if the camcorder is not used for approx. 3 months, the
clock's lithium battery will become discharged and the
date/time stored in memory will be lost. When this occurs,
first connect the camcorder to an AC outlet using the AC
Power Adapter/Charger for over 24 hours to charge the
clock's rechargeable lithium battery. Then perform the
date/time setting before using the camcorder.
Note that the camcorder can be used without setting the
date/time.
Your manual in English. You can use a smartphone with Google translate and the camera feature to read what is shown on the camera in Japanese and change the operating language to English.
http://www.videocamera-manual.com/manuals/jvc/JVC_GR-DVX9_MiniDV.pdf
JVC GR-DVX9 Mini... | Answered on Nov 04, 2017
Put it on fire and buy some good camcoder<br />
JVC GR-DVX9 Mini... | Answered on Aug 20, 2010
Following are the solutions:<br /> 1. Through your camera in dustbin;<br /> 2. crush it with hammer <br /> 3. Put it on fire
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
JVC GR Video... | Answered on Nov 13, 2017
not sure on this one but it might be the heads in your vid cam may need cleaning.
or the tapes are not running straight on the heads or the rollers in side.
if the vid cam has been in a cold place it can cause this fault as the heads may have a bit of damp.
try putting a tape in and run it fast forword in play mode and see if starts to clear the playhead.if it does keep doing it until you see a clear picture.
this could also be a head misalignment fault if it is you will have to take it to some one to have a look at.
if any of the above does not work then you will have to take to some one to look at it.
JVC GR Video... | Answered on Nov 27, 2016
Sounds as if the battery needs replacing - have you tried with a spare battery ?
JVC GR Video... | Answered on Oct 08, 2016
The heads need cleaning. DO NOT USE A HEAD CLEANING TAPE. Thats like holding sand paper to the drum. Use alcohol and a swab.
JVC GR Video... | Answered on Sep 12, 2016
Do you have the sd card that holds the pictures?
Put in computer.
Computer will give you option how to open and save photos.
You do not have to use makers software disc, any photo reader can store your pictures on computer.
JVC GR Video... | Answered on Nov 28, 2015
then don't push pause try record instead .
JVC GR Video... | Answered on Nov 21, 2015
JVC GR-DVX9 Mini DV Digital Camcorder Logo
15 questions posted
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GR JVC
  • GR JVC
Most Popular Question
when switch jvc grdvx9 says
  • Video Cameras
