20 Most Recent
JVC GR-D244 DV Digital Camcorder Questions & Answers
I am try to fix
You need a firewire cable and video editing software on your computer. Windows Moviemaker or Apple iMovie will edit the video, among others. There are two types of firewire ports, one is small and has 4 pins, and the other is larger and has 6 pins. Your camera has the 4 pin small plug and your computer will either have the 6 pin or the 4 pin, depending on the model and brand. Most desktops have the 6 pin, but some (particularly Sony) have the smaller 4 pin. Most laptops have the smaller 4 pin connector unless it is a Mac laptop it will have a 6 pin. So you will need a cable to fit both sides - 4 pin for the camera and either 4 or 6 pin for the computer.
Plug it in, put your camera in playback mode, start up your video software, and it should detect the camera and ask if you want to import the footage.
I want to connect my jvc gr-d244 to my computer to
you will need a firewire cable (ieee 1394).
you will also need a firewire port on your computer. if you don't have such a port you can buy a firewire pci card.
firewire looks similar to a usb port but it is different in size.
JVC GR-D290U Cam Corder.
I think your computer missing some video supporting codec that is why does not show picture.
Download and install
Cole2K Media Codec, hope that will solve your camcorder problem.
Thanks.
How to transfer the video in the web cam to the computer?
I use the software which came with the camera, and hit unload. It then downloads everything to the computer. To mover it to a CD or DVD I use windows explorer with copy and paste and not the programs supplied with winows vista. Easier to do.
Gr-ds44 cassette door will not close
I'm having the same problem. According to the manual you should try hooking the camcorder up to AV power to see if the problem is the battery, which is apparently not the problem in my case. Any other troubleshooting suggestions?
