20 Most Recent
JVC KW-AVX706 Car DVD Player Questions & Answers
Need color code for 16 pin connector, power plug
Pin Number
Wire Color
Function
White
Left Front Positive
Green
Left Rear Positive
Violet
Right Rear Positive
Grey
Right Front Positive
5
Blue/White
Amplifier Remote
6
Blue
Antenna Remote
7
Red
Accessory 12 Volts
8
Black
Ground
9
White/Black
Left Front Negative
10
Green/Black
Left Rear Negative
11
Violet/Black
Right Rear Negative
12
Grey/Black
Right Front Negative
13
Sky Blue
Telephone Mute
14
Orange/White
Illumination
15
Not Used
Not Used
16
Yellow
Constant 12 Volts
JVC KW-AVX706 front face problems
for ppl still having this problem.. more than likely the dash kit is to small and not allowing the radio to close properly. soulution: get one that fits, or get a dremel and shave down the plastic on the dash kit that prevents the radio from closing... hope this helps some1
I want to heek up
If the wire your referring to is blue/white it is to cut on external amplifiers. If you go to Crutchfield.com and type in your model number there is a pdf file for the manual on the right hand side about half way down, it will also show you what accessories for ipod control.
I have a jvc kw-avx706...is
Hello, there are two options. You could use a mini jack and plug it into your headphone jack on your Ipod and plug the other end into the aux jack on the front of your JVC unit. However you would have to have access to the ipod to control tracks and it will not charge the ipod. Or you could purchase a ipod cable that would not only charge but you would be able to control the ipod from the JVC unit. The part # KSU30 Crutchfield.com sells it for 39.99.
