20 Most Recent
JVC KD-G120 CD Player Questions & Answers
How do i set current time?
hold the sel button until different settings appear. use the tuning/ff/rev buttons to shuffle through the setting until you see the clock. use the volume control to change the hour then press the ff button to go to minute and adjust it as well. once done press the sel button to exit.
Resets when I turn ignition off
The yellow wire on your radio needs to be connected to an always hot fuse or wire. It is hooked to one now that is connected through the ignition, which is why it won't keep settings.
How do i take this out to install my subs
Your new stereo comes with stereo removal keys. They are the small pices of alominum that are about 3.5-4 inches long.. They insert on each side of your radio. If you don't have them then you must remove the section of the dash under the radio.
I have problem with reading cd why???????????
check the cd you are trying to play if you have recordable cd some players wont read disk also make sure the cd has the right format example mp3 wave also try to use a disc cleaner if laser is dirty
plz comment reply if you need more info
Is a remote wire and
no, they are not the same. the memory wire is to maintain the memory of preset stations and the clock. the remote wire is to turn an amp or power antenna on. on some radios there are two remote wires. one for power antenna and one for amplifier. power antenna is usually blue, and amplifier is usually blue/white.
The disk in the player
try either pressing the reset switch, if there is one, or disconnect power to the radio for a few minutes. you can do that by disconnecting the battery.
Does it have a fuse inside
All fuses are external.
You will find them on the red and yellow wires on the harness.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Which color is the memory wire im tired of
basically you have a power wire which should be wired to a switched connection and a memory wire which should be wired to a unswiched connection. look on your fuse box under the dash and connect the power wire first to a switched fuse (one that shuts off the radio when you turn off key) then look for a fuse (with same power wire )that when you turn off the key the radio stays on, this is the fuse that you connect the memory to,or you can connect the memory wire directly to the battery but you must use an inline fuse or you burn up your radio,car etc.
Installing CD Player in Peugeot 206
Hi dont know if anyone reads this still. First the finger tip control you have to rewire it into the new cd player with a Autoleads PC99-X26 - Peugeot 206 plus connection to your make of radio. Also the wireing problem some times is down to the red and yellow wires being the wrong way round swap them over and this should solve this.
