20 Most Recent
JVC KD-G220 CD Player Questions & Answers
Where is my remote wire input on my jvc g-220
Remote wire is for power antena or any other ancilliary unit is the blue with white stripe. You can find the installation manual on the jvc home page. Click on support and Instruction manual.
Cd player won't play cd's,
Have you tried to reset the unit firstly by pressing select AND on/off/att at the same time?
This will be warned delete all your preset settings.
The disc you are inserting has been played on the unit before?
Hope it helps
Installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This
connector fits the following JVC Car Radio/CD/MP3 Players with
16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Stored radio stations and time erase when car is turned off
The radio was installed incorrectlly. Make sure the red wire from the radio is connected to a switched 12 volt source(has voltage when car is on, none when it's off) The yellow wire to a constant 12 volt(hot at all times) this wire mantains the radio memory and must always have power.
Cant set the clock
Hi - You can download the manual from the link underlined in blue below:
jvc kd g220See page 10.
Please update the question & let us know if the information given was useful to you - Good Luck!
How set time jvc kd g220
Set Clock
- Hold the "SEL" button.
- Using the skip forward/backward buttons, select "Clock H".
- Use the rotary **** to adjust the hours.
- Using the skip forward/backward buttons, select "Clock M".
- Use the rotary **** to adjust the minutes.
Here is a
link to the owner's manual, as a reference (Page 10).
