20 Most Recent
JVC KD-G420 CD Player Questions & Answers
Need to get a manual
JVC does not give away this manual for some reason and wants to charge you for it so you can go to this link and order it. Good Luck
http://www.jvcservice.com/store/Model.asp?Model=KD-G420
KD-G310 How do I set the clock?
- 1. Press and hold (S) SEL Button
- 2. Canceling the display demonstrations Select "DEMO," then "DEMO OFF" Setting the clock
- Select "CLOCK H" (hour), then adjust the hour.
- Select "CLOCK M" (minute), then adjust the minute.
- 3. Press and hold (S) SEL Button to finish
How do you set the
1. Press and hold
(S) SEL Button
2.
- Canceling the display demonstrations Select "DEMO," then "DEMO OFF"
- Setting the clock
3. Press and hold
I WOULD LIKE TO OBTAIN
You can obtain the manual here, scroll down on the page, and give an email and enter the letters. The manual is free.
http://www.retrevo.com/support/JVC-KD-G420J-Car-Receivers-manual/id/989ci952/t/2/
Don't forget to vote
How do i eject the
Look at page nine of the following website. It should help you to review the ejection sequence of your stereo. Good Luck.
Stuck cd
if the eject button doesn't eject the disc the the CD mechanism is most likely damaged
Turns off over bump
The problem is the rotary encoder (volume knob) has a small internal insulator the breaks and allows contact. I repaired mine by replacing the component with one from Newark electronics, part # 02J2846, it is a Bourns rotary encoder part# PEC11-4215F-S0024. Simple solder skills and care are all that are needed and i think it is a slightly more durable component.
