20 Most Recent Reliable Of Milwaukee MSK-8550M Questions & Answers
The stitches wont interlock. We have threaded it
The first thing to check is that you have the correct needle for the machine. This machine is actually the same as the Singer model 20-U machine, which is a semi industrial machine. When you broke the first needle, you could have knocked the needle bar out of time. You can test this by inserting a new needle and lower it a little (about 16th") and try to manually pick up the thread. If it does pick it up, then put some fabric in and rotate the machine slowly by hand and see if it makes the stitches. If so, then the needle bar will have to be adjusted, or you are using the wrong sized needle. If you want, you can contact me at [email protected] and I will walk you through it.
1/27/2014 1:59:39 PM • Reliable Of... • Answered on Jan 27, 2014
Need manual MW30S1000GSH
You posted to sewing machines??? All questions need FULL 'make model (what it is )' as first 3 words. https://www.google.com/search?q=MW30S1000GSH+manual ..
4/14/2024 6:12:12 AM • Sewing Machines • Answered on Apr 14, 2024
My Empisal EM250 not sewing in zigzag
The spring needs to go back to where it came from. Unfortunately there is no parts schematic showing all the parts and where they go. You will either have to look inside for evidence of where it was, or take it to an Empisal service centre. https://www.google.com/search?q=Empisal+EM250+parts+schematic and Zig Zag fix videos https://www.google.com/search?q=Empisal+EM250+not+sewing+in+zigzag ..
4/7/2024 7:09:57 PM • Sewing Machines • Answered on Apr 07, 2024
2answers
Need a Nelco sewing machine mod 4102F manual.
  1. http://www.sewusa.com/index.htm try finding it on this website. maybe you will get lucky.
4/5/2024 4:36:42 PM • Sewing Machines • Answered on Apr 05, 2024
Janome 5002 english manual download
I need to repair janome 5002 model machine motherboard problem
4/3/2024 12:14:38 AM • Sewing Machines • Answered on Apr 03, 2024
2answers
My stitch for empisal cresta 2000 is slack, how to make it tight?
try increasing needle tension little by little
3/26/2024 2:15:14 PM • Sewing Machines • Answered on Mar 26, 2024
Site for manual on empisal companion 400 de lux won't even open. No video on threading it as well. Please!??
You should find one here if not in an obscure country; https://www.manuals.co.uk/sewing-machines/empisal
3/24/2024 3:35:34 PM • Sewing Machines • Answered on Mar 24, 2024
2answers
I need a manual on how to thread a Kingstar KS - 8700 sewing machine
Perhaps this link will help: Questions Answers for kingstar ks 8700 Sewing Machines ...
3/22/2024 4:49:59 PM • Sewing Machines • Answered on Mar 22, 2024
Designer 1 touch screen is frozen, and I cannot calibrate because reverse button is also stopped working.
When the Designer 1 touch screen is frozen and unresponsive, preventing you from calibrating or using the reverse button, it can be frustrating. Here are some steps you can try to troubleshoot and potentially resolve the issue: 1. Restart the Machine: - Turn off the Designer 1 embroidery machine and unplug it from the power source. - Wait for a few minutes before plugging it back in and turning it on. This can sometimes reset the system and resolve minor software glitches. 2. Check for Physical Obstructions: - Ensure that there are no physical obstructions on the touch screen that may be causing it to be unresponsive. Clean the screen gently with a soft, lint-free cloth to remove any dirt or debris. 3. Perform a Hard Reset: Performing a hard reset on the Designer 1 embroidery machine can help resolve software-related issues and reset the system to its default settings. Here is a general guide on how to perform a hard reset on the Designer 1 embroidery machine: A. Turn off the Machine: - Ensure that the Designer 1 embroidery machine is turned off and disconnected from the power source. B. Locate the Reset Button: - On some embroidery machines, including the Designer 1, there may be a small reset button located on the machine. - The reset button is typically a small, recessed button that may require a pin or a paperclip to press. C. Press the Reset Button: - Using a small pointed object like a pin or a paperclip, press and hold the reset button on the embroidery machine. - Hold the reset button for a few seconds (typically 10-15 seconds) to initiate the hard reset process. D. Release the Reset Button: - After holding the reset button for the specified time, release the button. E. Power On the Machine: - Plug the Designer 1 embroidery machine back into the power source and turn it on. - The machine should restart, and the hard reset process should be complete. F. Check Functionality: - Once the machine has restarted, check if the touch screen and other functions are responsive and working properly. - Test the touch screen, buttons, and other features to ensure that the hard reset has resolved the issue. (Please note that the exact steps for performing a hard reset may vary depending on the specific model and design of the Designer 1 embroidery machine. It is recommended to refer to the user manual or contact the manufacturer for specific instructions on performing a hard reset for your particular machine model.) If the hard reset does not resolve the issue with the frozen touch screen and unresponsive buttons on your Designer 1 embroidery machine, contact customer support or seek assistance from an authorized service center for further troubleshooting and repair. 4. Contact Customer Support: - If the touch screen remains frozen and unresponsive despite trying the above steps, it is recommended to contact the customer support service for the Designer 1 embroidery machine. - The customer support team can provide further guidance on troubleshooting the touch screen issue and may suggest additional steps to resolve the problem. 5. Professional Repair: - If the touch screen continues to be unresponsive and the machine is still under warranty, consider taking it to an authorized service center for repair. - Professional technicians can diagnose the issue and perform repairs if necessary to restore the functionality of the touch screen. It's essential to handle electronic devices like embroidery machines with care when troubleshooting issues to prevent any further damage. If you are unsure about performing any of the steps mentioned above, it's best to seek assistance from the manufacturer or a professional technician to avoid causing additional problems.
3/22/2024 3:16:04 AM • Sewing Machines • Answered on Mar 22, 2024
3answers
Bought a used Montgomery Ward 'Happy Lock' serger,
Would you sell a copy of your manual or pass along the source? Thank you.
3/16/2024 11:38:21 PM • Sewing Machines • Answered on Mar 16, 2024
How to turn safety lock off on nx-400
Initially, the "safety device has been activated" error is usually caused by a jammed thread or fabric. 2 possible causes The upper thread has become tangled around the bobbin case, The needle is bent and hitting the needle plate, so the machine stops. To fix this error. 1, Unplug your machine, 2. Remove the needle ( I know it is in a down position and locked up) but you can be able to remove it. 3. After removing the needle, turn your hand wheel if still locked up or stiff. Remove your needle plate and remove all your threads both upper and lower. 4. Clean your bobbin area using a brush take a deep breath then blow. 5. After that, try to turn your hand wheel again, if the hand wheel moves freely, rethread your machine and replace your needle with a new one. Then try to sew a few stitches using a hand wheel (do not sew using a pedal) if the hand wheel creates stitches that is the time to sew using the pedal. If the problem is still there, you possibly have broken gear that needs to be replaced
3/16/2024 2:25:45 AM • Sewing Machines • Answered on Mar 16, 2024
Janome 6500. What is causing my top thread to be able to pull it right out?? Looks fine but can pull the thread right up through the sewing.
Question edited for clarity. Your tension is incorrect, either the top tension is too tight or the bottom tension is too loose. Tension is a delicate tug of war between top and bottom thread to get the hooked loop of thread dead centre in the pieces of material. The is also a slight possibility that you are using a need that is too large and making a hole that is too big for the thread, and is making it loose. The top video is the best one ever made in the history of sewing machines.
Sewing Machine Tension - Top 10 TIPS and Settings
Treasurie https://blog.treasurie.com > Sewing > Sewing Techniques Loops on top of the fabric mean the top thread tension is too tight. Decrease tension (lower number) with small increases at a time. "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(70px);"> Rating: 4.9 · ‎ 39 votes ..
3/13/2024 10:43:01 PM • Sewing Machines • Answered on Mar 13, 2024
Need instruction manual for Tork Craft rotary tool
Yes
3/11/2024 5:57:16 AM • Sewing Machines • Answered on Mar 11, 2024
Ditch Witch 1620KE Trencher. I am looking for a service manual for it please.
Question edited for clarity. Duplicate question deleted, Refresh page to see your question Sewing Machines is probably not the best Category. Dealer Support and Manuals https://www.ditchwitch.com/support/ Operator and Maintenance Manuals https://www.google.com/search?q=Ditch+Witch+1620KE+Trencher+service+manual ..
3/9/2024 6:00:39 PM • Sewing Machines • Answered on Mar 09, 2024
JC Penney 6937 Free Arm Sewing Machine. What year would a model 6937 have been manufactured?
Question edited for clarity and better order. The problem is that JC Penney were just a department store seller of machines made by someone else, a regular sewing machine company, ie Singer, Necchi, Nelco, Brother..., but was badged under JC Penney's name.
J. C. Penney Co., Inc. - Serial Number Registry
VintageMachinery.org http://vintagemachinery.org > mfgindex > detail Manufacturers Index - J. C. Penney Co., Inc. ... There is currently no Serial Number Registry Steward for this manufacturer. ... manufacturer, please contact the ... https://en.wikipedia.org/wiki/JCPenney ..
3/9/2024 1:24:01 AM • Sewing Machines • Answered on Mar 09, 2024
Humvee HF-05 watch manual please?
Question edited for clarity, written backwards, add CAPS. I can normally move Category and get it out of Sewing Machines where you put it, but the mechanism to do that is broken so it will have to stay there forever. We have a Watch category.. It is a single crown watch. The crown has two or possibly three stop positions, the first ones do Day and Date and the furthest out does the time. https://www.google.com/search?q=Humvee+HF-05+watch+manual ..
2/28/2024 10:42:24 PM • Sewing Machines • Answered on Feb 28, 2024
Reliable Of Milwaukee MSK-8550M Logo
Popular Tags
0 questions posted
Top Reliable Of Milwaukee Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Reliable Of Milwaukee Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Reliable Of Milwaukee Sewing Machines
Most Popular Question
stitches wont interlock threaded
  • Sewing Machines
