20 Most Recent White Sewing 2200 Multi-Tasker Questions & Answers
2answers
My bobbin thread will not thread. When I bring
check the bobbin to make sure it's not warped
check the needle to make sure it's not bent-roll on flat surface to see if it roll correctly
make sure the bobbin is in the bobbin case correctly
make sure you have a 3 to 4 inch tail on the bobbin-so the upper thread can pick it up easily
make sure you have a 3 to 4 inch tail on upper thread also as it picks up the lower thread
or you can hold the upper thread with your hand to the side of the machine & use the handwheel to lower the needle as it picks up the lower thread
pull both threads to the back behind the needle
make sure there is no lint or loose threads in the bobbin area
8/14/2021 4:35:23 PM • White Sewing... • Answered on Aug 14, 2021
3answers
I've never used my White
Do you know what the 1 position is?
8/3/2017 2:45:30 PM • White Sewing... • Answered on Aug 03, 2017
How do i thread the thread
http://www.singerco.com/uploads/download/1132_white-2200-x-.pdf is the manual, complete with threading diagrams.
5/26/2014 1:57:14 AM • White Sewing... • Answered on May 26, 2014
0answers
0answers
The fabric isn't moving and the bobbing thread
when the fabric doesn't move then the feed dogs need to be checkedhere is a link for a free manual, if you don't have onehttp://www.singerco.com/uploads/download/1132_white-2200-x-.pdfcheck in the manual to see if it show where the feed dog lever is, if the feeddog is in the up position or down, it must be up for regular sewing, if it doesn't show the feed dog then the machine would have to be taken in to a sewing machine shop to have the feed dog checkedtry changing the needlemake sure the bobbin is inserted correctly into the bobbin case and make sure the bobbin is turned the right way in the bobbin case
9/26/2013 11:20:28 AM • White Sewing... • Answered on Sep 26, 2013
0answers
How to oil
Be the first to answer 8/7/2013 4:47:05 AM • White Sewing... • Posted on Aug 07, 2013Be the first to answer
0answers
White line 2200 singer manual
You may download a copy of the manual here.
12/1/2012 4:04:37 PM • White Sewing... • Answered on Dec 01, 2012
Manual for singer 2200
here's a link for a free manual, just click on the linkhttp://www.singerco.com/uploads/download/1132_white-2200-x-.pdf
10/24/2012 10:49:28 PM • White Sewing... • Answered on Oct 24, 2012
How do I load the bobbin?
10/15/2012 1:13:16 PM • White Sewing... • Answered on Oct 15, 2012
My sewing machine will not pick up the bobbin thread
If a sewing machine fails to pick up the bobbin thread, it's usually because the needle isn't fully in the needle bar... OR its the wrong size needle for the machine.
7/27/2012 1:27:01 AM • White Sewing... • Answered on Jul 27, 2012
Cannot locate my manual at moment and need to know
typically you need to increase the upper tension to 7-8 for very heavy duty materials, I like to start with the machine at like 4 and increase till it is just perfect. Good luck with your project.
2/11/2011 6:51:20 PM • White Sewing... • Answered on Feb 11, 2011
White Sewing 2200 Multi-Tasker Logo
40 questions posted
Top White Sewing Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • White Sewing Sewing Machines
Most Popular Question
fabric isnt moving bobbing thread
  • Sewing Machines
