20 Most Recent
Lexar JumpDrive MP3 Player Questions & Answers
When I turn on the
Hi there.
Connect it to pc and find it in 'my computer', open it up. Click on
view/select all and move the songs to your pc. Right click the player
icon, select format/FAT, ignore 'Quick format' , then virus scan all
your songs, and move them back onto player.
Hope this helps. Let me know if you have further questions.
Thank you!
Lexar mda256-100 player from bose
The solution is correct. I emailed
[email protected] and received an email the next day with a firmware patch that reformatted my player.
Just an FYI, this did NOT work under Vista and since I had an XP media center laptop sitting next to me I didn't play with it. On the XP system it worked flawlessly. I ended up with a fully functional MP3 player again, nothing in the folder at all and it only took a minute.
Send them an email and I would expect you'd get a response within 1-2 business days. As mentioned, my response was within 18 hours.
It won;t pop up
PUT IT ON A CHARGER OVERNITE, AT LEAST 4 HOURS. do NOT use your cp as a charger if u can hlep it
Lexar MP3 Player 100
Attach
MP3 to
computer.
Open explorer and right click the
MP3 drive letter.
Choose
FORMATNext window choose
FAT32 and
Quick as the options.
Transfered Music to Flashdrive but can not load to another PC/IPO
That happens to me on occasion. Have you tried putting the jump drive into a different PC? Try reconnecting it and being patient. Waiting up to five minutes sometimes helps.
If you're going through a USB hub of any kind (like a port on a keyboard or monitor) then bypass it. Try connecting directly to the machine.
Reformat the player
Attach
MP3 to
computer.
MP3 drive letter.
Choose
FAT32 and
Lexar MP3
Attach MP3 to computer.
Open explorer and right click the MP3 drive letter.
Choose FORMAT
Next window choose FAT32 and Quick as the options.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
